Build(deps): Bump rubocop-ast from 0.4.0 to 0.4.1 (PR #10683)
Bumps rubocop-ast from 0.4.0 to 0.4.1.
Changelog
Sourced from rubocop-ast's changelog.
0.4.1 (2020-09-16)
Bug fixes
  • #115: Fix ConstNode#absolute? when the constant is not namespaced. ([@dvandersluis][])
Commits
  • 079dce2 Cut 0.4.1
  • d09aa14 Fix ConstNode#absolute? raising NoMethodError when the constant is not na...
  • c457a21 Update for Lint/ConstantDefinitionInBlock
  • b4cd5c9 NodePattern specs: introduce match_code matcher.
  • a93f45f Tweak Gemfile, bug was fixed
  • 8fc3767 Restore docs/antora.yml
  • See full diff in compare view
GitHub
