Build(deps): Bump rubocop-ast from 0.4.1 to 0.4.2 (PR #10705)
Bumps rubocop-ast from 0.4.1 to 0.4.2.
Changelog
Sourced from rubocop-ast's changelog.
0.4.2 (2020-09-18)
Bug fixes
  • #116: Fix issues with tokens being sometimes misordered. ([@fatkodima][])
Commits
GitHub
