Build(deps): Bump rubocop-ast from 0.4.2 to 0.5.0 (PR #10744)
Bumps rubocop-ast from 0.4.2 to 0.5.0.
Changelog
Sourced from rubocop-ast's changelog.
0.5.0 (2020-09-24)
New features
Changes
  • #121: Update from Parser::Ruby28 to Parser::Ruby30 for Ruby 3.0 parser (experimental). ([@koic][])
Commits
  • c67e5ad Cut 0.5.0
  • aa7975e Add Node#parent? and Node#root?
  • 4adf4b2 Update from Parser::Ruby28 to Parser::Ruby30 for Ruby 3.0 parser
  • 746171c parse_source: allow direct targetting of a node
  • 0c89003 Remove repetitive tests
  • 92f6745 Fix "Node#source" for case with no expression
  • c3add0a Restore docs/antora.yml
  • c9ad72b Fix typo
  • See full diff in compare view
GitHub
