Build(deps): Bump rubocop-ast from 0.5.1 to 0.7.0 (PR #10754)
Bumps rubocop-ast from 0.5.1 to 0.7.0.
Changelog
Sourced from rubocop-ast's changelog.
0.7.0 (2020-09-27)
New features
Changes
  • #22: (Potentially breaking) Most constants are now private, the rest are converted to Sets and meant to be private. ([@marcandre][])
0.6.0 (2020-09-26)
New features
Commits
  • c13ffdf Cut 0.7.0
  • 8185f4a Insure generated files are up to date when building / releasing
  • b808be0 Optimize Node#recursive_{basic_}literal?
  • 35a5aca Mark the rest as API private and convert to Sets
  • acd2b30 Make most constants private.
  • 51cdbf7 Add NodePattern support for Regexp literals.
  • 1f83679 Optimize some NodePatterns by using Sets
  • e28920a Add NodePattern support for multiple terms unions
  • b9171b0 Add NodePattern debugging rake tasks: test_pattern, compile, parse
  • 2ca9c08 NodePattern compiler complete rewrite. Add support for multiple variadic te...
  • Additional commits viewable in compare view
GitHub
