Build(deps): Bump rubocop-ast from 0.7.0 to 0.7.1 (PR #10765)
Bumps rubocop-ast from 0.7.0 to 0.7.1.
Changelog
Sourced from rubocop-ast's changelog.
0.7.1 (2020-09-28)
Commits
  • ee9c173 Cut 0.7.1
  • 0cfbcac Avoid using StringScanner#captures, any strscan lib will do
  • 17d697d Revert "[Fixes #125] Use source URL until official doc site is update"
  • 8e313fb [Fixes #125] Use source URL until official doc site is update
  • bc5ebf2 Restore docs/antora.yml
  • See full diff in compare view
GitHub
