Build(deps): Bump rubocop-ast from 0.7.1 to 0.8.0 (PR #10912)
Bumps rubocop-ast from 0.7.1 to 0.8.0.
Changelog
Sourced from rubocop-ast's changelog.
0.8.0 (2020-10-12)
New features
  • #49: Add DefNode#endless? (Ruby 3.0). ([@marcandre][])
  • #117: Future-proof AST::Traversal by detecting unknown Node types. ([@marcandre][])
  • #131: Add rake tasks to merge and create Changelog entries. ([@marcandre][])
Bug fixes
  • #117: All nodes of break and next are now traversed. ([@marcandre][])
Commits
GitHub
