Build(deps): Bump rubocop-ast from 1.10.0 to 1.11.0 (PR #14134)
Bumps rubocop-ast from 1.10.0 to 1.11.0.
Changelog
Sourced from rubocop-ast's changelog.
1.11.0 (2021-08-24)
New features
  • #205: Make class, module, and struct definitions aware of numblock. ([@​koic][])
Commits
GitHub
