Build(deps): Bump rubocop-ast from 1.11.0 to 1.12.0 (PR #14467)
Bumps rubocop-ast from 1.11.0 to 1.12.0.
Changelog
Sourced from rubocop-ast's changelog.
1.12.0 (2021-09-27)
Bug fixes
  • #208: Update MethodDispatchNode#block_literal? to return true for numblocks. ([@​dvandersluis][])
Commits
GitHub
