Build(deps): Bump rubocop-ast from 1.12.0 to 1.13.0 (PR #14850)
Bumps rubocop-ast from 1.12.0 to 1.13.0.
Changelog
Sourced from rubocop-ast's changelog.
1.13.0 (2021-11-07)
New features
  • #213: Make Node#numeric_type? aware of rational and complex literals. ([@​koic][])
Commits
GitHub
