Build(deps): Bump rubocop-ast from 1.4.1 to 1.5.0 (PR #12924)
Bumps rubocop-ast from 1.4.1 to 1.5.0.
Changelog
Sourced from rubocop-ast's changelog.
1.5.0 (2021-05-02)
New features
  • #182: Support Parser::Ruby31 for Ruby 3.1 parser (experimental). ([@​koic][])
1.4.2 (2021-05-02)
Bug fixes
  • #179: Have ast_with_comments distinguish nodes with same content. ([@​marcandre][])
Commits
GitHub
