Build(deps): Bump rubocop-ast from 1.6.0 to 1.7.0 (PR #13205)
Bumps rubocop-ast from 1.6.0 to 1.7.0.
Changelog
Sourced from rubocop-ast's changelog.
1.7.0 (2021-05-28)
New features
  • #171: Add SendNode#def_modifier that returns the def node it modifies, or nil. ([@​marcandre][])
  • #186: Add pattern method for AST::InPatternNode node. ([@​koic][])
Commits
GitHub
