Build(deps): Bump rubocop from 0.82.0 to 0.83.0 (PR #9750)
Bumps rubocop from 0.82.0 to 0.83.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.83
New features
  • #7951: Include rakefile file by default. (@jethrodaniel)
  • #7921: Add new Style/SlicingWithRange cop. (@zverok)
  • #7895: Include .simplecov file by default. (@robotdana)
  • #7916: Support autocorrection for Lint/AmbiguousRegexpLiteral. (@koic)
  • #7917: Support autocorrection for Lint/UselessAccessModifier. (@koic)
  • #595: Add ERB pre-processing for configuration files. (@jonas054)
  • #7918: Support autocorrection for Lint/AmbiguousOperator. (@koic)
  • #7937: Support autocorrection for Style/IfWithSemicolon. (@koic)
  • #3696: Add AllowComments option to Lint/EmptyWhen cop. (@koic)
  • #7910: Support autocorrection for Lint/ParenthesesAsGroupedExpression. (@koic)
  • #7925: Support autocorrection for Layout/ConditionPosition. (@koic)
  • #7934: Support autocorrection for Lint/EnsureReturn. (@koic)
  • #7922: Add new Layout/EmptyLineAroundAttributeAccessor cop. (@koic)
Bug fixes
  • #7929: Fix Style/FrozenStringLiteralComment to accept frozen_string_literal anywhere in leading comment lines. (@jeffcarbs)
  • #7882: Fix Style/CaseEquality when AllowOnConstant is true and the method receiver is implicit. (@rafaelfranca)
  • #7790: Fix --parallel and --ignore-parent-exclusion combination. (@jonas054)
  • #7881: Fix --parallel and --force-default-config combination. (@jonas054)
  • #7635: Fix a false positive for Style/MultilineWhenThen when then required for a body of when is used. (@koic)
  • #7905: Fix an error when running rubocop --only or rubocop --except options without cop name argument. (@koic)
  • #7903: Fix an incorrect autocorrect for Style/HashTransformKeys and Style/HashTransformValues cops when line break before to_h method. ([@diogoosorio][], @koic)
  • #7899: Fix an infinite loop error for Layout/SpaceAroundOperators with Layout/ExtraSpacing when using ForceEqualSignAlignment: true. (@koic)
  • #7885: Fix Style/IfUnlessModifier logic when tabs are used for indentation. (@jonas054)
  • #7909: Fix a false positive for Lint/ParenthesesAsGroupedExpression when using an intended grouped parentheses. (@koic)
  • #7913: Fix a false positive for Lint/LiteralAsCondition when using true literal in while and similar cases. (@koic)
  • #7928: Fix a false message for Style/GuardClause when using and or or operators for guard clause in then or else branches. (@koic)
  • #7928: Fix a false positive for Style/GuardClause when assigning the result of a guard condition with else. (@koic)
Changes
  • #7860: Change AllowInHeredoc option of Layout/TrailingWhitespace to true by default. (@koic)
  • #7094: Clarify alignment in Layout/MultilineOperationIndentation. (@jonas054)
  • #4245: (Breaking) Inspect all files given on command line unless --only-recognized-file-types is given. (@jonas054)
  • #7390: (Breaking) Enabling a cop overrides disabling its department. (@jonas054)
  • #7936: Mark Lint/BooleanSymbol as unsafe. ([@laurmurclar][])
  • #7948: Mark unsafe for Style/OptionalArguments. (@koic)
  • #7931: Remove dependency on the jaro_winkler gem, instead depending on did_you_mean. This may be a breaking change for RuboCop libraries calling NameSimilarity#find_similar_name. ([@bquorning][])
... (truncated)
Changelog
Sourced from rubocop's changelog.
0.83.0 (2020-05-11)
New features
  • #7951: Include rakefile file by default. ([@jethrodaniel][])
  • #7921: Add new Style/SlicingWithRange cop. ([@zverok][])
  • #7895: Include .simplecov file by default. ([@robotdana][])
  • #7916: Support autocorrection for Lint/AmbiguousRegexpLiteral. ([@koic][])
  • #7917: Support autocorrection for Lint/UselessAccessModifier. ([@koic][])
  • #595: Add ERB pre-processing for configuration files. ([@jonas054][])
  • #7918: Support autocorrection for Lint/AmbiguousOperator. ([@koic][])
  • #7937: Support autocorrection for Style/IfWithSemicolon. ([@koic][])
  • #3696: Add AllowComments option to Lint/EmptyWhen cop. ([@koic][])
  • #7910: Support autocorrection for Lint/ParenthesesAsGroupedExpression. ([@koic][])
  • #7925: Support autocorrection for Layout/ConditionPosition. ([@koic][])
  • #7934: Support autocorrection for Lint/EnsureReturn. ([@koic][])
  • #7922: Add new Layout/EmptyLineAroundAttributeAccessor cop. ([@koic][])
Bug fixes
  • #7929: Fix Style/FrozenStringLiteralComment to accept frozen_string_literal anywhere in leading comment lines. ([@jeffcarbs][])
  • #7882: Fix Style/CaseEquality when AllowOnConstant is true and the method receiver is implicit. ([@rafaelfranca][])
  • #7790: Fix --parallel and --ignore-parent-exclusion combination. ([@jonas054][])
  • #7881: Fix --parallel and --force-default-config combination. ([@jonas054][])
  • #7635: Fix a false positive for Style/MultilineWhenThen when then required for a body of when is used. ([@koic][])
  • #7905: Fix an error when running rubocop --only or rubocop --except options without cop name argument. ([@koic][])
  • #7903: Fix an incorrect autocorrect for Style/HashTransformKeys and Style/HashTransformValues cops when line break before to_h method. ([@diogoosorio][], [@koic][])
  • #7899: Fix an infinite loop error for Layout/SpaceAroundOperators with Layout/ExtraSpacing when using ForceEqualSignAlignment: true. ([@koic][])
  • #7885: Fix Style/IfUnlessModifier logic when tabs are used for indentation. ([@jonas054][])
  • #7909: Fix a false positive for Lint/ParenthesesAsGroupedExpression when using an intended grouped parentheses. ([@koic][])
  • #7913: Fix a false positive for Lint/LiteralAsCondition when using true literal in while and similar cases. ([@koic][])
  • #7928: Fix a false message for Style/GuardClause when using and or or operators for guard clause in then or else branches. ([@koic][])
  • #7928: Fix a false positive for Style/GuardClause when assigning the result of a guard condition with else. ([@koic][])
Changes
  • #7860: Change AllowInHeredoc option of Layout/TrailingWhitespace to true by default. ([@koic][])
  • #7094: Clarify alignment in Layout/MultilineOperationIndentation. ([@jonas054][])
  • #4245: (Breaking) Inspect all files given on command line unless --only-recognized-file-types is given. ([@jonas054][])
  • #7390: (Breaking) Enabling a cop overrides disabling its department. ([@jonas054][])
  • #7948: Mark unsafe for Style/OptionalArguments. ([@koic][])
Commits
  • bc62e24 Cut 0.83
  • 21a864f Merge pull request #7951 from jethrodaniel/rakefile
  • d64060f add rakefile (lowercase) to default config
  • 2a82508 Tweak a changelog entry
  • 063b4a8 Remove dependency on jaro_winkler
  • c92a591 Use DidYouMean
  • fd3ba1f Change find_similar_name to a module_function
  • 77b59de Simplify NameSimilarity.find_similar_name
  • 865930c Add new Layout/EmptyLineAroundAttributeAccessor cop
  • ee2d393 Mark unsafe for Style/OptionalArguments cop
  • Additional commits viewable in compare view
GitHub
