Build(deps): Bump rubocop from 0.83.0 to 0.84.0 (PR #9849)
Bumps rubocop from 0.83.0 to 0.84.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.84
New features
  • #7735: NodePattern and AST classes have been moved to the rubocop-ast gem. (@marcandre)
  • #7950: Add new Lint/DeprecatedOpenSSLConstant cop. (@bdewater)
  • #7976: Add AllowAliasSyntax and AllowedMethods options for Layout/EmptyLinesAroundAttributeAccessor. (@koic)
  • #7984: New rake task "check_commit" will run rspec and rubocop on files touched by the last commit. (@marcandre)
Bug fixes
  • #7953: Fix an error for Lint/AmbiguousOperator when a method with no arguments is used in advance. (@koic)
  • #7962: Fix a false positive for Lint/ParenthesesAsGroupedExpression when heredoc has a space between the same string as the method name and (. (@koic)
  • #7967: Style/SlicingWithRange cop now supports any expression as its first index. (@zverok)
  • #7972: Fix an incorrect autocrrect for Style/HashSyntax when using a return value uses return. (@koic)
  • #7886: Fix a bug in AllowComments logic in Lint/SuppressedException. (@jonas054)
  • #7991: Fix an error for Layout/EmptyLinesAroundAttributeAccessor when attribute method is method chained. (@koic)
  • #7993: Fix a false positive for Migration/DepartmentName when a disable comment contains an unexpected character for department name. (@koic)
Changes
  • #7952: (Breaking) Change the max line length of Layout/LineLength to 120 by default. (@koic)
  • #7959: Change enforced style to conditionals for Style/AndOr. (@koic)
  • #7985: Add EnforcedStyle for Style/DoubleNegation cop and allow double nagation in contexts that use boolean as a return value. (@koic)
Changelog
Sourced from rubocop's changelog.
0.84.0 (2020-05-21)
New features
  • #7735: NodePattern and AST classes have been moved to the rubocop-ast gem. ([@marcandre][])
  • #7950: Add new Lint/DeprecatedOpenSSLConstant cop. ([@bdewater][])
  • #7976: Add AllowAliasSyntax and AllowedMethods options for Layout/EmptyLinesAroundAttributeAccessor. ([@koic][])
  • #7984: New rake task "check_commit" will run rspec and rubocop on files touched by the last commit. ([@marcandre][])
Bug fixes
  • #7953: Fix an error for Lint/AmbiguousOperator when a method with no arguments is used in advance. ([@koic][])
  • #7962: Fix a false positive for Lint/ParenthesesAsGroupedExpression when heredoc has a space between the same string as the method name and (. ([@koic][])
  • #7967: Style/SlicingWithRange cop now supports any expression as its first index. ([@zverok][])
  • #7972: Fix an incorrect autocrrect for Style/HashSyntax when using a return value uses return. ([@koic][])
  • #7886: Fix a bug in AllowComments logic in Lint/SuppressedException. ([@jonas054][])
  • #7991: Fix an error for Layout/EmptyLinesAroundAttributeAccessor when attribute method is method chained. ([@koic][])
  • #7993: Fix a false positive for Migration/DepartmentName when a disable comment contains an unexpected character for department name. ([@koic][])
Changes
  • #7952: (Breaking) Change the max line length of Layout/LineLength to 120 by default. ([@koic][])
  • #7959: Change enforced style to conditionals for Style/AndOr. ([@koic][])
  • #7985: Add EnforcedStyle for Style/DoubleNegation cop and allow double nagation in contexts that use boolean as a return value. ([@koic][])
Commits
  • 10a6f91 Fix the release notes
  • d7bfd36 Cut 0.84
  • 119d695 Add doc for disabling comment style
  • 82ded12 [Fix #7993] Fix a false positive for Migration/DepartmentName
  • 2a57489 Add a .dir-locals.el
  • c7fe5da Remove unneeded let for specs using :config shared environment
  • 3c91822 Refactor config shared context. Simplify some specs.
  • 4d694e3 Spec: remove trailing whitespace
  • 2e8f013 Lint/SuppressedException: Explicit AllowComments config in spec
  • 36d3e30 Lint/EmptyWhen Add explicit config that is differing from default #7999
  • Additional commits viewable in compare view
GitHub
