Build(deps): Bump rubocop from 0.86.0 to 0.87.0 (PR #10174)
Bumps rubocop from 0.86.0 to 0.87.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.87
New features
  • #7868: Cop::Base is the new recommended base class for cops. (@marcandre)
  • #3983: Add new Style/AccessorGrouping cop. (@fatkodima)
  • #8244: Add new Style/BisectedAttrAccessor cop. (@fatkodima)
  • #7458: Add new AsciiConstants option for Naming/AsciiIdentifiers. (@fatkodima)
  • #7373: Add new Style/RedundantAssignment cop. (@fatkodima)
  • #8213: Permit to specify TargetRubyVersion 2.8 (experimental). (@koic)
  • #8159: Add new CountAsOne option for code length related Metric cops. (@fatkodima)
  • #8164: Support auto-correction for Lint/InterpolationCheck. (@koic)
  • #8223: Support auto-correction for Style/IfUnlessModifierOfIfUnless. (@koic)
  • #8172: Support auto-correction for Lint/SafeNavigationWithEmpty. (@koic)
Bug fixes
  • #8039: Fix false positives for Lint/ParenthesesAsGroupedExpression in when using operators or chain functions. (@CamilleDrapier)
  • #8196: Fix a false positive for Style/RedundantFetchBlock when using with Rails.cache. (@fatkodima)
  • #8195: Fix an error for Style/RedundantFetchBlock when using #fetch with empty block. (@koic)
  • #8193: Fix a false positive for Style/RedundantRegexpCharacterClass when using [\b]. (@owst)
  • #8205: Fix a false positive for Style/RedundantRegexpCharacterClass when using a leading escaped ]. (@owst)
  • #8208: Fix Style/RedundantParentheses with hash literal as first argument to yield. (@karlwithak)
  • #8176: Don't load .rubocop.yml from personal folders to check for exclusions if there's a project configuration. (@deivid-rodriguez)
Changes
  • #7868: (Breaking) Extensive refactoring of internal classes Team, Commissioner, Corrector. Cop::Cop#corrections not completely compatible. See Upgrade Notes. (@marcandre)
  • #8156: (Breaking) rubocop -a / --autocorrect no longer run unsafe corrections; rubocop -A / --autocorrect-all run both safe and unsafe corrections. Options --safe-autocorrect is deprecated. (@marcandre)
  • #8207: (Breaking) Order for gems names now disregards underscores and dashes unless ConsiderPunctuation setting is set to true. (@marcandre)
  • #8211: Style/ClassVars cop now detects class_variable_set. (@biinari)
  • #8245: Detect top-level constants like ::Const in various cops. (@biinari)
Changelog
Sourced from rubocop's changelog.
0.87.0 (2020-07-06)
New features
  • #7868: Cop::Base is the new recommended base class for cops. ([@marcandre][])
  • #3983: Add new Style/AccessorGrouping cop. ([@fatkodima][])
  • #8244: Add new Style/BisectedAttrAccessor cop. ([@fatkodima][])
  • #7458: Add new AsciiConstants option for Naming/AsciiIdentifiers. ([@fatkodima][])
  • #7373: Add new Style/RedundantAssignment cop. ([@fatkodima][])
  • #8213: Permit to specify TargetRubyVersion 2.8 (experimental). ([@koic][])
  • #8159: Add new CountAsOne option for code length related Metric cops. ([@fatkodima][])
  • #8164: Support auto-correction for Lint/InterpolationCheck. ([@koic][])
  • #8223: Support auto-correction for Style/IfUnlessModifierOfIfUnless. ([@koic][])
  • #8172: Support auto-correction for Lint/SafeNavigationWithEmpty. ([@koic][])
Bug fixes
  • #8039: Fix false positives for Lint/ParenthesesAsGroupedExpression in when using operators or chain functions. ([@CamilleDrapier][])
  • #8196: Fix a false positive for Style/RedundantFetchBlock when using with Rails.cache. ([@fatkodima][])
  • #8195: Fix an error for Style/RedundantFetchBlock when using #fetch with empty block. ([@koic][])
  • #8193: Fix a false positive for Style/RedundantRegexpCharacterClass when using [\b]. ([@owst][])
  • #8205: Fix a false positive for Style/RedundantRegexpCharacterClass when using a leading escaped ]. ([@owst][])
  • #8208: Fix Style/RedundantParentheses with hash literal as first argument to yield. ([@karlwithak][])
  • #8176: Don't load .rubocop.yml from personal folders to check for exclusions if there's a project configuration. ([@deivid-rodriguez][])
Changes
  • #7868: (Breaking) Extensive refactoring of internal classes Team, Commissioner, Corrector. Cop::Cop#corrections not completely compatible. See Upgrade Notes. ([@marcandre][])
  • #8156: (Breaking) rubocop -a / --autocorrect no longer run unsafe corrections; rubocop -A / --autocorrect-all run both safe and unsafe corrections. Options --safe-autocorrect is deprecated. ([@marcandre][])
  • #8207: (Breaking) Order for gems names now disregards underscores and dashes unless ConsiderPunctuation setting is set to true. ([@marcandre][])
  • #8211: Style/ClassVars cop now detects class_variable_set. ([@biinari][])
  • #8245: Detect top-level constants like ::Const in various cops. ([@biinari][])
Commits
  • ba8f13a Cut 0.87
  • 040e829 Changelog entry for #8245
  • 5e03e9b Allow top-level const in MutableConst
  • 91820ea Detect top-level const in ExpandPathArguments
  • bc268f8 Detect top-level const in RandomWithOffset
  • a59d579 Detect redundant ::RuntimeError in raise/fail
  • ce20cb4 Detect ::ENV in Style/RedundantFreeze
  • dbc3794 Allow top-level const in Style/ZeroLengthPredicate
  • d0de34a Allow ::Proc.new with arg in Style/SymbolProc
  • d499386 Detect ::Struct in Style/StructInheritance
  • Additional commits viewable in compare view
GitHub
Superseded by #10184.
