Build(deps): Bump rubocop from 0.86.0 to 0.87.1 (PR #10184)
Bumps rubocop from 0.86.0 to 0.87.1.
Release notes
Sourced from rubocop's releases.
RuboCop 0.87.1
Bug fixes
  • #8252: Fix a command line option name from --safe-autocorrect to --safe-auto-correct, which is compatible with RuboCop 0.86 and lower. (@koic)
  • #8259: Fix false positives for Style/BisectedAttrAccessor when accessors have different access modifiers. (@fatkodima)
  • #8253: Fix false positives for Style/AccessorGrouping when accessors have different access modifiers. (@fatkodima)
  • #8257: Fix an error for Style/BisectedAttrAccessor when using attr_reader and attr_writer with splat arguments. (@fatkodima)
  • #8239: Don't load .rubocop.yml from personal folders to check for exclusions if given a custom configuration file. (@deivid-rodriguez)
  • #8256: Fix an error for --auto-gen-config when running a cop who do not support auto-correction. (@koic)
  • #8262: Fix Lint/DeprecatedOpenSSLConstant auto-correction of OpenSSL::Cipher to use lower case, as some Linux-based systems do not accept upper cased cipher names. (@bdewater)
RuboCop 0.87
New features
  • #7868: Cop::Base is the new recommended base class for cops. (@marcandre)
  • #3983: Add new Style/AccessorGrouping cop. (@fatkodima)
  • #8244: Add new Style/BisectedAttrAccessor cop. (@fatkodima)
  • #7458: Add new AsciiConstants option for Naming/AsciiIdentifiers. (@fatkodima)
  • #7373: Add new Style/RedundantAssignment cop. (@fatkodima)
  • #8213: Permit to specify TargetRubyVersion 2.8 (experimental). (@koic)
  • #8159: Add new CountAsOne option for code length related Metric cops. (@fatkodima)
  • #8164: Support auto-correction for Lint/InterpolationCheck. (@koic)
  • #8223: Support auto-correction for Style/IfUnlessModifierOfIfUnless. (@koic)
  • #8172: Support auto-correction for Lint/SafeNavigationWithEmpty. (@koic)
Bug fixes
  • #8039: Fix false positives for Lint/ParenthesesAsGroupedExpression in when using operators or chain functions. ([@CamilleDrapier][])
  • #8196: Fix a false positive for Style/RedundantFetchBlock when using with Rails.cache. (@fatkodima)
  • #8195: Fix an error for Style/RedundantFetchBlock when using #fetch with empty block. (@koic)
  • #8193: Fix a false positive for Style/RedundantRegexpCharacterClass when using [\b]. ([@owst][])
  • #8205: Fix a false positive for Style/RedundantRegexpCharacterClass when using a leading escaped ]. ([@owst][])
  • #8208: Fix Style/RedundantParentheses with hash literal as first argument to yield. ([@karlwithak][])
  • #8176: Don't load .rubocop.yml from personal folders to check for exclusions if there's a project configuration. (@deivid-rodriguez)
Changes
  • #7868: (Breaking) Extensive refactoring of internal classes Team, Commissioner, Corrector. Cop::Cop#corrections not completely compatible. See Upgrade Notes. (@marcandre)
  • #8156: (Breaking) rubocop -a / --autocorrect no longer run unsafe corrections; rubocop -A / --autocorrect-all run both safe and unsafe corrections. Options --safe-autocorrect is deprecated. (@marcandre)
  • #8207: (Breaking) Order for gems names now disregards underscores and dashes unless ConsiderPunctuation setting is set to true. (@marcandre)
  • #8211: Style/ClassVars cop now detects class_variable_set. ([@biinari][])
  • #8245: Detect top-level constants like ::Const in various cops. ([@biinari][])
Changelog
Sourced from rubocop's changelog.
0.87.1 (2020-07-07)
Bug fixes
  • #8252: Fix a command line option name from --safe-autocorrect to --safe-auto-correct, which is compatible with RuboCop 0.86 and lower. ([@koic][])
  • #8259: Fix false positives for Style/BisectedAttrAccessor when accessors have different access modifiers. ([@fatkodima][])
  • #8253: Fix false positives for Style/AccessorGrouping when accessors have different access modifiers. ([@fatkodima][])
  • #8257: Fix an error for Style/BisectedAttrAccessor when using attr_reader and attr_writer with splat arguments. ([@fatkodima][])
  • #8239: Don't load .rubocop.yml from personal folders to check for exclusions if given a custom configuration file. ([@deivid-rodriguez][])
  • #8256: Fix an error for --auto-gen-config when running a cop who do not support auto-correction. ([@koic][])
  • #8262: Fix Lint/DeprecatedOpenSSLConstant auto-correction of OpenSSL::Cipher to use lower case, as some Linux-based systems do not accept upper cased cipher names. ([@bdewater][])
0.87.0 (2020-07-06)
New features
  • #7868: Cop::Base is the new recommended base class for cops. ([@marcandre][])
  • #3983: Add new Style/AccessorGrouping cop. ([@fatkodima][])
  • #8244: Add new Style/BisectedAttrAccessor cop. ([@fatkodima][])
  • #7458: Add new AsciiConstants option for Naming/AsciiIdentifiers. ([@fatkodima][])
  • #7373: Add new Style/RedundantAssignment cop. ([@fatkodima][])
  • #8213: Permit to specify TargetRubyVersion 2.8 (experimental). ([@koic][])
  • #8159: Add new CountAsOne option for code length related Metric cops. ([@fatkodima][])
  • #8164: Support auto-correction for Lint/InterpolationCheck. ([@koic][])
  • #8223: Support auto-correction for Style/IfUnlessModifierOfIfUnless. ([@koic][])
  • #8172: Support auto-correction for Lint/SafeNavigationWithEmpty. ([@koic][])
Bug fixes
  • #8196: Fix a false positive for Style/RedundantFetchBlock when using with Rails.cache. ([@fatkodima][])
  • #8195: Fix an error for Style/RedundantFetchBlock when using #fetch with empty block. ([@koic][])
  • #8176: Don't load .rubocop.yml from personal folders to check for exclusions if there's a project configuration. ([@deivid-rodriguez][])
Changes
  • #7868: (Breaking) Extensive refactoring of internal classes Team, Commissioner, Corrector. Cop::Cop#corrections not completely compatible. See Upgrade Notes. ([@marcandre][])
  • #8156: (Breaking) rubocop -a / --autocorrect no longer run unsafe corrections; rubocop -A / --autocorrect-all run both safe and unsafe corrections. Options --safe-autocorrect is deprecated. ([@marcandre][])
  • #8207: (Breaking) Order for gems names now disregards underscores and dashes unless ConsiderPunctuation setting is set to true. ([@marcandre][])
Commits
  • de0f2e8 Cut 0.87.1
  • 9b2ff38 Fix false positives for Style/BisectedAttrAccessor when accessors have diff...
  • 698a17f Merge pull request #8262 from bdewater/openssl-lower-case-constant
  • d8541a4 Fix Lint/DeprecatedOpenSSLConstant auto-correction of OpenSSL::Cipher to use ...
  • caef6bb Fix false positives for Style/AccessorGrouping when accessors have differen...
  • 85ff4c3 Fix an error for Style/BisectedAttrAccessor when using attr_reader and `a...
  • 0d09c1b [Fix #8256] Fix an error for --auto-gen-config when running a cop without a...
  • 5bcf201 [Docs] Tweak some markup
  • ee4f5dc Add a note about the --config flag
  • a743015 Don't load exclusions from personal files when passing a config with custom name
  • Additional commits viewable in compare view
GitHub
