Build(deps): Bump rubocop from 0.87.1 to 0.88.0 (PR #10226)
Bumps rubocop from 0.87.1 to 0.88.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.88
New features
Bug fixes
  • #8232: Fix a false positive for Layout/EmptyLinesAroundAccessModifier when end immediately after access modifier. (@koic)
  • #7777: Fix crash for Layout/MultilineArrayBraceLayout when comment is present after last element. (@shekhar-patil)
  • #7776: Fix crash for Layout/MultilineMethodCallBraceLayout when comment is present before closing braces. (@shekhar-patil)
  • #8282: Fix Style/IfUnlessModifier bad precedence detection. (@tejasbubane)
  • #8289: Fix Style/AccessorGrouping to not register offense for accessor with comment. (@tejasbubane)
  • #8310: Handle major version requirements in Gemspec/RequiredRubyVersion. (@eugeneius)
  • #8315: Fix crash for Style/PercentLiteralDelimiters when the source contains invalid characters. (@eugeneius)
  • #8239: Don't load .rubocop.yml files at all outside of the current project, unless they are personal configuration files and the project has no configuration. (@deivid-rodriguez)
Changes
  • #8021: Rewrite Layout/SpaceAroundMethodCallOperator cop to make it faster. (@fatkodima)
  • #8294: Add of to AllowedNames of MethodParameterName cop. (@AlexWayfer)
Changelog
Sourced from rubocop's changelog.
0.88.0 (2020-07-13)
New features
  • #8279: Recognise require method passed as argument in Lint/NonDeterministicRequireOrder cop. ([@biinari][])
  • #7333: Add new Style/RedundantFileExtensionInRequire cop. ([@fatkodima][])
  • #8316: Support autocorrect for Lint/DisjunctiveAssignmentInConstructor cop. ([@fatkodima][])
  • #8242: Internal profiling available with bin/rubocop-profile and rake tasks. ([@marcandre][])
  • #8295: Add new Style/ArrayCoercion cop. ([@fatkodima][])
  • #8293: Add new Lint/DuplicateElsifCondition cop. ([@fatkodima][])
  • #7736: Add new Style/CaseLikeIf cop. ([@fatkodima][])
  • #4286: Add new Style/HashAsLastArrayItem cop. ([@fatkodima][])
  • #8247: Add new Style/HashLikeCase cop. ([@fatkodima][])
  • #8286: Internal method expect_offense allows abbreviated offense messages. ([@marcandre][])
Bug fixes
  • #8232: Fix a false positive for Layout/EmptyLinesAroundAccessModifier when end immediately after access modifier. ([@koic][])
  • #7777: Fix crash for Layout/MultilineArrayBraceLayout when comment is present after last element. ([@shekhar-patil][])
  • #7776: Fix crash for Layout/MultilineMethodCallBraceLayout when comment is present before closing braces. ([@shekhar-patil][])
  • #8282: Fix Style/IfUnlessModifier bad precedence detection. ([@tejasbubane][])
  • #8289: Fix Style/AccessorGrouping to not register offense for accessor with comment. ([@tejasbubane][])
  • #8310: Handle major version requirements in Gemspec/RequiredRubyVersion. ([@eugeneius][])
  • #8315: Fix crash for Style/PercentLiteralDelimiters when the source contains invalid characters. ([@eugeneius][])
  • #8239: Don't load .rubocop.yml files at all outside of the current project, unless they are personal configuration files and the project has no configuration. ([@deivid-rodriguez][])
Changes
  • #8021: Rewrite Layout/SpaceAroundMethodCallOperator cop to make it faster. ([@fatkodima][])
  • #8294: Add of to AllowedNames of MethodParameterName cop. ([@AlexWayfer][])
Commits
  • acddd73 Cut 0.88
  • 535c544 Add a changelog entry
  • d1822bc Ignore configuration files outside of the project
  • e1a2da0 Only look up to the project's root for exclusions
  • 0563861 Fix traverse_files_upwards to make searching up to the root possible
  • 18e318f Merge pull request #8279 from Fatsoma/feature/require_order_block_pass
  • fe066fc Merge branch 'master' into feature/require_order_block_pass
  • 0c786c0 Fix line number for empty file offense
  • 930b65f Fix expect_offense when annotations missing
  • 34a2dbd Merge pull request #8316 from fatkodima/autocorrect-to-disjunctive_assignment...
  • Additional commits viewable in compare view
GitHub
The lints are passing and we need to keep marching ahead. Merging
