Build(deps): Bump rubocop from 0.88.0 to 0.89.0 (PR #10381)
Bumps rubocop from 0.88.0 to 0.89.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.89
New features
Bug fixes
  • #8346: Allow parentheses in single-line inheritance with Style/MethodCallWithArgsParentheses EnforcedStyle: omit_parentheses to fix invalid Ruby auto-correction. ([@gsamokovarov][])
  • #8324: Fix crash for Layout/SpaceAroundMethodCallOperator when using Proc#call shorthand syntax. ([@fatkodima][])
  • #8332: Fix auto-correct in Style/ConditionalAssignment to preserve constant namespace. ([@biinari][])
  • #8344: Fix crash for Style/CaseLikeIf when checking against equal? and match? without a receiver. ([@fatkodima][])
  • #8323: Fix a false positive for Style/HashAsLastArrayItem when hash is not a last array item. ([@fatkodima][])
  • #8299: Fix an incorrect auto-correct for Style/RedundantCondition when using raise, rescue, or and without argument parentheses in else. ([@koic][])
  • #8335: Fix incorrect character class detection for nested or POSIX bracket character classes in Style/RedundantRegexpEscape. ([@owst][])
  • #8347: Fix an incorrect auto-correct for EnforcedStyle: hash_rockets of Style/HashSyntax with Layout/HashAlignment. ([@koic][])
  • #8375: Fix an infinite loop error for Style/EmptyMethod. ([@koic][])
  • #8385: Remove auto-correction for Lint/EnsureReturn. ([@marcandre][])
  • #8391: Mark Style/ArrayCoercion as not safe. ([@marcandre][])
  • #8406: Improve Style/AccessorGrouping's auto-correction to remove redundant blank lines. ([@koic][])
  • #8330: Fix a false positive for Style/MissingRespondToMissing when defined method with inline access modifier. ([@koic][])
  • #8422: Fix an error for Lint/SelfAssignment when using or-assignment for constant. ([@koic][])
  • #8423: Fix an error for Style/SingleArgumentDig when without a receiver. ([@koic][])
  • #8424: Fix an error for Lint/IneffectiveAccessModifier when there is begin...end before a method definition. ([@koic][])
  • #8006: Fix line length calculation for Style/IfUnlessModifier to correctly take into account code before the if condition when considering conversation to a single-line form. ([@dsavochkin][])
  • #8283: Fix line length calculation for Style/IfUnlessModifier to correctly take into account a comment on the first line when considering conversation to a single-line form. ([@dsavochkin][])
  • #7957: Fix line length calculation for Style/IfUnlessModifier to correctly take into account code on the last line after the end keyword when considering conversion to a single-line form. ([@dsavochkin][])
  • #8226: Fix Style/IfUnlessModifier to add parentheses when converting if-end condition inside an array or a hash to a single-line form. ([@dsavochkin][])
  • #8443: Fix an incorrect auto-correct for Style/StructInheritance when there is a comment before class declaration. ([@koic][])
  • #8444: Fix an error for Layout/FirstMethodArgumentLineBreak when using kwargs in super. ([@koic][])
Changes
  • #8376: Style/MethodMissingSuper cop is removed in favor of new Lint/MissingSuper cop. ([@fatkodima][])
Changelog
Sourced from rubocop's changelog.
0.89.0 (2020-08-05)
New features
Bug fixes
Changes
Commits
  • 829c782 Cut 0.89
  • 6042aed Small Style cops perf tweaks
  • a678aba [Fixes #7755] Add Lint/OutOfRangeRefInRegexp cop (#8407)
  • 1fc1981 Fix move namespaced constant in Style/ConditionalAssignment (#8332)
  • f91df3e Add new Lint/EmptyConditionalBody cop
  • 7048b51 Enhance Gemspec/RequiredRubyVersion cop with check that `required_ruby_vers...
  • 426814e Support autocorrect for Lint/Loop cop
  • c29441f Optimize getting node tokens
  • d94c4a4 Add new Lint/BinaryOperatorWithIdenticalOperands cop
  • bf47e35 Don't mutate arguments.
  • Additional commits viewable in compare view
GitHub
