Build(deps): Bump rubocop from 0.89.0 to 0.89.1 (PR #10405)
Bumps rubocop from 0.89.0 to 0.89.1.
Release notes
Sourced from rubocop's releases.
RuboCop 0.89.1
Bug fixes
  • #8463: Fix false positives for Lint/OutOfRangeRegexpRef when a regexp is defined and matched in separate steps. (@eugeneius)
  • #8464: Handle regexps matched with when, grep, gsub, gsub!, sub, sub!, [], slice, slice!, scan, index, rindex, partition, rpartition, start_with?, and end_with? in Lint/OutOfRangeRegexpRef. (@eugeneius)
  • #8466: Fix a false positive for Lint/UriRegexp when using regexp method without receiver. (@koic)
  • #8478: Relax Lint/BinaryOperatorWithIdenticalOperands for mathematical operations. (@marcandre)
  • #8480: Tweak callback list of Lint/MissingSuper. (@marcandre)
  • #8481: Fix autocorrect for elements with newlines in Style/SymbolArray and Style/WordArray. (@biinari)
  • #8475: Fix a false positive for Style/HashAsLastArrayItem when there are duplicate hashes in the array. (@wcmonty)
  • #8497: Fix Style/IfUnlessModifier to add parentheses when converting if-end condition inside a parenthesized method argument list. (@dsavochkin)
Changes
  • #8487: Detect < and > as comparison operators in Style/ConditionalAssignment cop. (@biinari)
Changelog
Sourced from rubocop's changelog.
0.89.1 (2020-08-10)
Bug fixes
  • #8463: Fix false positives for Lint/OutOfRangeRegexpRef when a regexp is defined and matched in separate steps. ([@eugeneius][])
  • #8464: Handle regexps matched with when, grep, gsub, gsub!, sub, sub!, [], slice, slice!, scan, index, rindex, partition, rpartition, start_with?, and end_with? in Lint/OutOfRangeRegexpRef. ([@eugeneius][])
  • #8466: Fix a false positive for Lint/UriRegexp when using regexp method without receiver. ([@koic][])
  • #8478: Relax Lint/BinaryOperatorWithIdenticalOperands for mathematical operations. ([@marcandre][])
  • #8480: Tweak callback list of Lint/MissingSuper. ([@marcandre][])
  • #8481: Fix autocorrect for elements with newlines in Style/SymbolArray and Style/WordArray. ([@biinari][])
  • #8475: Fix a false positive for Style/HashAsLastArrayItem when there are duplicate hashes in the array. ([@wcmonty][])
  • #8497: Fix Style/IfUnlessModifier to add parentheses when converting if-end condition inside a parenthesized method argument list. ([@dsavochkin][])
Changes
  • #8487: Detect < and > as comparison operators in Style/ConditionalAssignment cop. ([@biinari][])
Commits
  • e27942a Cut 0.89.1
  • 3cba823 [Fix #8497] Fix Style/IfUnlessModifier to handle if-end condition in method a...
  • 78f1ec9 Alter multiline memoization message for braces enforced style
  • e0f28e0 Deprecate comment_lines?
  • 9a08fde Avoid use of ProcessedSource#commented?
  • 28eabb7 Fix Style/EmptyCaseCondition's autocorrect.
  • 14a5c20 Avoid comments_before_line
  • 8a02e42 Simplify and optimize comment lookup
  • a0ec799 New rubocop-ast insures that ProcessedSource#comments is never nil.
  • 7fd90a4 Avoid use of each_comment
  • Additional commits viewable in compare view
GitHub
