Build(deps): Bump rubocop from 0.89.1 to 0.90.0 (PR #10569)
Bumps rubocop from 0.89.1 to 0.90.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.90
New features
Bug fixes
  • #8508: Fix a false positive for Style/CaseLikeIf when conditional contains comparison with a class. Mark Style/CaseLikeIf as not safe. (@fatkodima)
  • #8618: Fix an infinite loop error for Layout/EmptyLineBetweenDefs. (@fatkodima)
  • #8534: Fix Lint/BinaryOperatorWithIdenticalOperands for binary operators used as unary operators. (@marcandre)
  • #8537: Allow a trailing comment as a description comment for Bundler/GemComment. (@pocke)
  • #8507: Fix Style/RescueModifier to handle parentheses around rescue modifiers. (@dsavochkin)
  • #8527: Prevent an incorrect auto-correction for Style/CaseEquality cop when comparing with === against a regular expression receiver. ([@koic][])
  • #8524: Fix Layout/EmptyLinesAroundClassBody and Layout/EmptyLinesAroundModuleBody to correctly handle an access modifier as a first child. (@dsavochkin)
  • #8518: Fix Lint/ConstantResolution cop reporting offense for module and class definitions. ([@tejasbubane][])
  • #8158: Fix Style/MultilineWhenThen cop to correctly handle cases with multiline body. (@dsavochkin)
  • #7705: Fix Style/OneLineConditional cop to handle if/then/elsif/then/else/end cases. Add AlwaysCorrectToMultiline config option to this cop to always convert offenses to the multi-line form (false by default). ([@Lykos][], @dsavochkin)
  • #8590: Fix an error when auto-correcting encoding mismatch file. ([@koic][])
  • #8321: Enable auto-correction for Layout/{Def}EndAlignment, Lint/EmptyEnsure, Style/ClassAndModuleChildren. (@marcandre)
  • #8583: Fix Style/RedundantRegexpEscape false positive for line continuations. ([@owst][])
  • #8593: Fix Style/RedundantRegexpCharacterClass false positive for interpolated multi-line expressions. ([@owst][])
  • #8624: Fix an error with the Style/CaseLikeIf cop where it does not properly handle overridden equality methods with no arguments. ([@Skipants][])
Changes
  • #8413: Pending cops warning now contains snippet that can be directly copied into .rubocop.yml as well as a notice about NewCops: enable config option. ([@colszowka][])
  • #8362: Add numbers of correctable offenses to summary. ([@nguyenquangminh0711][])
  • #8513: Clarify the ruby warning mentioned in the Lint/ShadowingOuterLocalVariable documentation. ([@chocolateboy][])
  • #8517: Make Style/HashTransformKeys and Style/HashTransformValues aware of to_h with block. ([@eugeneius][])
  • #8529: Mark Lint/FrozenStringLiteralComment as Safe, but with unsafe auto-correction. (@marcandre)
  • #8602: Fix usage of to_enum(:scan, regexp) to work on TruffleRuby. ([@jaimerave][])
Changelog
Sourced from rubocop's changelog.
0.90.0 (2020-09-01)
New features
Bug fixes
  • #8508: Fix a false positive for Style/CaseLikeIf when conditional contains comparison with a class. Mark Style/CaseLikeIf as not safe. ([@fatkodima][])
  • #8618: Fix an infinite loop error for Layout/EmptyLineBetweenDefs. ([@fatkodima][])
  • #8534: Fix Lint/BinaryOperatorWithIdenticalOperands for binary operators used as unary operators. ([@marcandre][])
  • #8537: Allow a trailing comment as a description comment for Bundler/GemComment. ([@pocke][])
  • #8507: Fix Style/RescueModifier to handle parentheses around rescue modifiers. ([@dsavochkin][])
  • #8524: Fix Layout/EmptyLinesAroundClassBody and Layout/EmptyLinesAroundModuleBody to correctly handle an access modifier as a first child. ([@dsavochkin][])
  • #8158: Fix Style/MultilineWhenThen cop to correctly handle cases with multiline body. ([@dsavochkin][])
  • #7705: Fix Style/OneLineConditional cop to handle if/then/elsif/then/else/end cases. Add AlwaysCorrectToMultiline config option to this cop to always convert offenses to the multi-line form (false by default). ([@Lykos][], [@dsavochkin][])
  • #8321: Enable auto-correction for Layout/{Def}EndAlignment, Lint/EmptyEnsure, Style/ClassAndModuleChildren. ([@marcandre][])
Changes
  • #8529: Mark Lint/FrozenStringLiteralComment as Safe, but with unsafe auto-correction. ([@marcandre][])
Commits
  • 95305ff Cut 0.90
  • eb04490 Merge pull request #8595 from marcandre/struct_autocorrect
  • 71c4818 Merge branch 'master' into struct_autocorrect
  • 6d781b0 Revert "Mark Cops and Formatters as private"
  • f69a7a8 Merge pull request #8624 from Skipants/master
  • f877e02 Fix Style/CaseLikeIf not properly handling overriden equality methods
  • 6cab599 Add workaround to avoid crash in Truffleruby (#8602)
  • 2b7607c Fix an infinite loop error for Layout/EmptyLineBetweenDefs
  • 31a921d Use Cop::Base API for Layout department [T-Z]
  • 6c05f69 Use Cop::Base API for Layout department [N-S]
  • Additional commits viewable in compare view
GitHub
