Build(deps): Bump rubocop from 0.91.1 to 0.92.0 (PR #10745)
Bumps rubocop from 0.91.1 to 0.92.0.
Release notes
Sourced from rubocop's releases.
RuboCop 0.92
New features
Bug fixes
  • #8774: Fix a false positive for Layout/ArrayAlignment with parallel assignment. (@dvandersluis)
Changes
  • #8785: Update TargetRubyVersion 2.8 to 3.0 (experimental). (@koic)
  • #8650: Faster find of hidden files in TargetFinder class which improves rubocop initial startup speed. (@tleish)
  • #8783: Disable Style/ArrayCoercion cop by default. (@koic)
Changelog
Sourced from rubocop's changelog.
0.92.0 (2020-09-25)
New features
Bug fixes
  • #8774: Fix a false positive for Layout/ArrayAlignment with parallel assignment. ([@dvandersluis][])
Changes
  • #8785: Update TargetRubyVersion 2.8 to 3.0 (experimental). ([@koic][])
  • #8650: Faster find of hidden files in TargetFinder class which improves rubocop initial startup speed. ([@tleish][])
  • #8783: Disable Style/ArrayCoercion cop by default. ([@koic][])
Commits
GitHub
