Build(deps): Bump rubocop from 1.13.0 to 1.14.0 (PR #12955)
Bumps rubocop from 1.13.0 to 1.14.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.14
New features
Bug fixes
  • #9751: Style/StringLiteral doesn't autocorrect global variable interpolation. (@​etiennebarrie)
  • #9731: Fix two autocorrection issues for Style/NegatedIfElseCondition. (@​dvandersluis)
  • #9740: Fix an incorrect auto-correct for Style/SingleLineMethods when defining setter method. (@​koic)
  • #9757: Fix a false positive for Lint/NumberConversion when :to_f is one of multiple method arguments. (@​koic)
  • #9761: Fix Style/ClassAndModuleChildren false negative for compact style when a class/module is partially nested. (@​dvandersluis)
  • #9748: Prevent infinite loops during symlink traversal. (@​Tonkpils)
  • #9762: Update VariableForce to be able to handle case-match nodes. (@​dvandersluis)
  • #9729: Fix an error for Style/IfUnlessModifier when variable assignment is used in the branch body of if modifier. (@​koic)
  • #9750: Fix an incorrect auto-correct for Style/SoleNestedConditional when when using nested if within unless foo == bar. (@​koic)
  • #9751: Style/StringLiteral autocorrects '\\' into "\\". (@​etiennebarrie)
  • #9732: Support deprecated Socket.gethostbyaddr and Socket.gethostbyname. (@​AndreiEres)
  • #9713: Fix autocorrection for block local variables in Lint/UnusedBlockArgument. (@​tejasbubane)
  • #9746: Fix a false positive for Lint/UnreachableLoop when using conditional next in a loop. (@​koic)
Changelog
Sourced from rubocop's changelog.
1.14.0 (2021-05-05)
New features
Bug fixes
  • #9751: Style/StringLiteral doesn't autocorrect global variable interpolation. ([@​etiennebarrie][])
  • #9731: Fix two autocorrection issues for Style/NegatedIfElseCondition. ([@​dvandersluis][])
  • #9740: Fix an incorrect auto-correct for Style/SingleLineMethods when defining setter method. ([@​koic][])
  • #9757: Fix a false positive for Lint/NumberConversion when :to_f is one of multiple method arguments. ([@​koic][])
  • #9761: Fix Style/ClassAndModuleChildren false negative for compact style when a class/module is partially nested. ([@​dvandersluis][])
  • #9748: Prevent infinite loops during symlink traversal. ([@​Tonkpils][])
  • #9762: Update VariableForce to be able to handle case-match nodes. ([@​dvandersluis][])
  • #9729: Fix an error for Style/IfUnlessModifier when variable assignment is used in the branch body of if modifier. ([@​koic][])
  • #9750: Fix an incorrect auto-correct for Style/SoleNestedConditional when when using nested if within unless foo == bar. ([@​koic][])
  • #9751: Style/StringLiteral autocorrects '\\' into "\\". ([@​etiennebarrie][])
  • #9732: Support deprecated Socket.gethostbyaddr and Socket.gethostbyname. ([@​AndreiEres][])
  • #9713: Fix autocorrection for block local variables in Lint/UnusedBlockArgument. ([@​tejasbubane][])
  • #9746: Fix a false positive for Lint/UnreachableLoop when using conditional next in a loop. ([@​koic][])
Commits
  • 2283fe4 Cut 1.14
  • 9421ac0 Update Changelog
  • 762655e [Fix #7669] Add Bundler/GemVersion cop (#9727)
  • 8384d34 [Fix #9761] Fix Style/ClassAndModuleChildren false negative for compact s...
  • d0df484 Merge pull request #9764 from dvandersluis/issue/9762
  • 8f00479 [Fix #9762] Update VariableForce to be able to handle case-match nodes.
  • c165e90 Don't autocorrect global variable interpolation
  • c5f7dd6 Autocorrect '\' when double-quotes are preferred
  • 22274c6 Prevent infinite loops during symlink traversal
  • 2c39d51 Add changelog
  • Additional commits viewable in compare view
GitHub
