Build(deps): Bump rubocop from 1.14.0 to 1.15.0 (PR #13079)
Bumps rubocop from 1.14.0 to 1.15.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.15
New features
Bug fixes
  • #9749: Fix autocorrection for Layout/LineLength to not move the first argument of an unparenthesized send node to the next line, which changes behaviour. (@​dvandersluis)
  • #9799: Fix invalid line splitting by Layout/LineLength for send nodes with heredoc arguments. (@​dvandersluis)
  • #9773: Fix Style/EmptyLiteral to not register offenses for String.new when Style/FrozenStringLiteral is enabled. (@​dvandersluis)
  • #9771: Change AllowDSLWriters to true by default for Style/TrivialAccessors. (@​koic)
  • #9777: Fix an incorrect auto-correct for Style/RedundantBegin when using multi-line if in begin block. (@​koic)
  • #9791: Fix a false negative for Layout/IndentationWidth when using ensure in do ... end block. (@​koic)
  • #9766: Fix a clobbering error for Style/ClassAndModuleChildren cop with compact style. (@​tejasbubane)
  • #9767: Fix Style/ClassAndModuleChildren cop to preserve comments. (@​tejasbubane)
  • #9792: Fix false positive for Lint/Void cop with ranges. (@​tejasbubane)
Changes
  • #9770: Update Lint/EmptyBlock to handle procs the same way as lambdas. (@​dvandersluis)
  • #9776: Update Style/NilLambda to handle procs as well. (@​dvandersluis)
  • #9744: The parallel flag will now be automatically ignored when combined with --cache false. Previously, an error was raised and execution stopped. (@​rrosenblum)
Changelog
Sourced from rubocop's changelog.
1.15.0 (2021-05-17)
New features
Bug fixes
  • #9749: Fix autocorrection for Layout/LineLength to not move the first argument of an unparenthesized send node to the next line, which changes behaviour. ([@​dvandersluis][])
  • #9799: Fix invalid line splitting by Layout/LineLength for send nodes with heredoc arguments. ([@​dvandersluis][])
  • #9773: Fix Style/EmptyLiteral to not register offenses for String.new when Style/FrozenStringLiteral is enabled. ([@​dvandersluis][])
  • #9771: Change AllowDSLWriters to true by default for Style/TrivialAccessors. ([@​koic][])
  • #9777: Fix an incorrect auto-correct for Style/RedundantBegin when using multi-line if in begin block. ([@​koic][])
  • #9791: Fix a false negative for Layout/IndentationWidth when using ensure in do ... end block. ([@​koic][])
  • #9766: Fix a clobbering error for Style/ClassAndModuleChildren cop with compact style. ([@​tejasbubane][])
  • #9767: Fix Style/ClassAndModuleChildren cop to preserve comments. ([@​tejasbubane][])
  • #9792: Fix false positive for Lint/Void cop with ranges. ([@​tejasbubane][])
Changes
  • #9770: Update Lint/EmptyBlock to handle procs the same way as lambdas. ([@​dvandersluis][])
  • #9776: Update Style/NilLambda to handle procs as well. ([@​dvandersluis][])
  • #9744: The parallel flag will now be automatically ignored when combined with --cache false. Previously, an error was raised and execution stopped. ([@​rrosenblum][])
Commits
  • 9c9b891 Cut 1.15
  • b92be6a Update Changelog
  • eecc7c8 Tweak some wording
  • b3e567c [Fix #9767] Fix Style/ClassAndModuleChildren cop to preserve comments
  • dca0471 [Change #9744] Auto disable parallel when combined with cache false
  • 40d0970 [Fix #9792] Fix false positive for Lint/Void cop
  • 4f13546 Merge pull request #9801 from dvandersluis/issue/9749
  • fcde5d7 Merge pull request #9800 from dvandersluis/issue/9799
  • 60834d4 [Fix #9749] Fix autocorrection for Layout/LineLength to not move the first ...
  • 1d81c00 [Fix #9799] Fix invalid line splitting by Layout/LineLength for send node...
  • Additional commits viewable in compare view
GitHub
