Build(deps): Bump rubocop from 1.16.1 to 1.17.0 (PR #13392)
Bumps rubocop from 1.16.1 to 1.17.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.17
New features
  • #9626: Disable all cop department with directive comment. (@​AndreiEres)
  • #9827: Add basic auth support to download raw yml config from private repo. (@​AirWick219)
  • #9873: Support one-line pattern matching syntax for Layout/SpaceAroundKeyword and Layout/SpaceAroundOperators. (@​koic)
  • #9857: Support Ruby 2.7's pattern matching for Layout/IndentationWidth cop. (@​koic)
  • #9877: Support Ruby 2.7's in pattern syntax for Lint/LiteralAsCondition. (@​koic)
  • #9855: Support Ruby 2.7's pattern matching for Style/IdenticalConditionalBranches cop. (@​koic)
Bug fixes
  • #9874: Fix a false positive for Style/RegexpLiteral when using %r regexp literal with EnforcedStyle: omit_parentheses of Style/MethodCallWithArgsParentheses. (@​koic)
  • #9876: Fix empty line after guard clause with and return and heredoc. (@​AndreiEres)
  • #9861: Fix error in Layout/HashAlignment with an empty hash literal. (@​dvandersluis)
  • #9867: Fix an incorrect auto-correct for Layout/DotPosition when using only dot line. (@​koic)
Changelog
Sourced from rubocop's changelog.
1.17.0 (2021-06-15)
New features
  • #9626: Disable all cop department with directive comment. ([@​AndreiEres][])
  • #9827: Add basic auth support to download raw yml config from private repo. ([@​AirWick219][])
  • #9873: Support one-line pattern matching syntax for Layout/SpaceAroundKeyword and Layout/SpaceAroundOperators. ([@​koic][])
  • #9857: Support Ruby 2.7's pattern matching for Layout/IndentationWidth cop. ([@​koic][])
  • #9877: Support Ruby 2.7's in pattern syntax for Lint/LiteralAsCondition. ([@​koic][])
  • #9855: Support Ruby 2.7's pattern matching for Style/IdenticalConditionalBranches cop. ([@​koic][])
Bug fixes
  • #9874: Fix a false positive for Style/RegexpLiteral when using %r regexp literal with EnforcedStyle: omit_parentheses of Style/MethodCallWithArgsParentheses. ([@​koic][])
  • #9876: Fix empty line after guard clause with and return and heredoc. ([@​AndreiEres][])
  • #9861: Fix error in Layout/HashAlignment with an empty hash literal. ([@​dvandersluis][])
  • #9867: Fix an incorrect auto-correct for Layout/DotPosition when using only dot line. ([@​koic][])
Commits
  • 0f4e3d1 Cut 1.17
  • 44e1970 Update Changelog
  • 956a9b1 Merge pull request #9878 from koic/fix_false_positive_for_style_regexp_literal
  • 7cf773e [Fix #9874] Fix a false positive for Style/RegexpLiteral
  • 76fc82b Fix empty line after guard clause with and return and heredoc
  • f313e6f [Fix #9519] Make it possible to disable an entire department with a directive...
  • 2815917 Support Ruby 2.7's in pattern syntax for Lint/LiteralAsCondition
  • 4fed3f7 Support one-line pattern matching syntax
  • 40ecfcf Use Cop::Base API for Layout/RedundantLineBreak
  • 9584b01 Clarify that you can raise exceptions without arguments
  • Additional commits viewable in compare view
GitHub
