Build(deps): Bump rubocop from 1.17.0 to 1.18.0 (PR #13572)
Bumps rubocop from 1.17.0 to 1.18.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.18
New features
Bug fixes
  • #9803: Fix Bundler/GemVersion cop not respecting git tags. (@​tejasbubane, @​timlkelly)
  • #9882: Fix an incorrect auto-correct for Layout/LineLength when using heredoc as the first method argument and omitting parentheses. (@​koic)
  • #7592: Add cop Layout/LineEndStringConcatenationIndentation. (@​jonas054)
  • #9880: Fix a false positive for Style/RegexpLiteral when using a regexp starts with a blank as a method argument. (@​koic)
  • #9888: Fix a false positive for Layout/ClosingParenthesisIndentation when using keyword arguemnts. (@​koic)
  • #9886: Fix indentation in Style/ClassAndModuleChildren. (@​markburns)
Changes
  • #9144: Add aggressive and conservative modes of operation for Style/StringConcatenation cop. (@​tejasbubane)
Changelog
Sourced from rubocop's changelog.
1.18.0 (2021-06-29)
New features
Bug fixes
  • #9803: Fix Bundler/GemVersion cop not respecting git tags. ([@​tejasbubane][], [@​timlkelly][])
  • #9882: Fix an incorrect auto-correct for Layout/LineLength when using heredoc as the first method argument and omitting parentheses. ([@​koic][])
  • #7592: Add cop Layout/LineEndStringConcatenationIndentation. ([@​jonas054][])
  • #9880: Fix a false positive for Style/RegexpLiteral when using a regexp starts with a blank as a method argument. ([@​koic][])
  • #9888: Fix a false positive for Layout/ClosingParenthesisIndentation when using keyword arguemnts. ([@​koic][])
  • #9886: Fix indentation in Style/ClassAndModuleChildren. ([@​markburns][])
Changes
  • #9144: Add aggressive and conservative modes of operation for Style/StringConcatenation cop. ([@​tejasbubane][])
Commits
  • f1f6414 Cut 1.18
  • 8f3bde2 Update Changelog
  • 9b5402d [Fixes #9144] Add aggressive and conservative modes for `Style/StringConc...
  • 0170f53 Fix a typo
  • 89463f6 Fix a false positive for Layout/ClosingParenthesisIndentation
  • 8ff511c Update changelog/fix_gem_version_not_respecting_tags.md
  • 19390ca Update Bundler/GemVersion to check for branch, ref, and tag
  • 4326083 [Fix #9803] Fix Bundler/GemVersion cop not respecting git tags
  • 356b22c Fix indentation in Style/ClassAndModuleChildren
  • aadf475 Fix a build error
  • Additional commits viewable in compare view
GitHub
