Build(deps): Bump rubocop from 1.18.1 to 1.18.2 (PR #13627)
Bumps rubocop from 1.18.1 to 1.18.2.
Release notes
Sourced from rubocop's releases.
RuboCop 1.18.2
Bug fixes
Changelog
Sourced from rubocop's changelog.
1.18.2 (2021-07-02)
Bug fixes
  • #9894: Handle multiline string literals in Layout/LineEndStringConcatenationIndentation. ([@​jonas054][])
  • #9890: Make colon after comment annotation configurable. ([@​gregfletch][])
Commits
GitHub
