Build(deps): Bump rubocop from 1.18.2 to 1.18.3 (PR #13653)
Bumps rubocop from 1.18.2 to 1.18.3.
Release notes
Sourced from rubocop's releases.
RuboCop 1.18.3
Bug fixes
  • #9891: Fix --auto-gen-config bug for Style/HashSyntax. (@​jonas054)
  • #9905: Fix false positive for single line concatenation in Layout/LineEndStringConcatenationIndentation. (@​jonas054)
  • #9907: Fix an incorrect auto-correct for Lint/UselessTimes when using block argument for 1.times. (@​koic)
  • #9869: Fix reference to file in configuration override warning. (@​jonas054)
  • #9902: Fix an incorrect auto-correct for Style/BlockDelimiters when there is a comment after the closing brace. (@​koic)
  • #8469: Add inspection of class << to Layout/SpaceAroundOperators. (@​jonas054)
  • #9909: This PR fixes an incorrect auto-correct for Style/SingleLineMethods when using return, break, or next for one line method body in Ruby 3.0. (@​koic)
  • #9914: Fix an error for Layout/HashAlignment when using aligned hash argument for proc.(). (@​koic)
Changelog
Sourced from rubocop's changelog.
1.18.3 (2021-07-06)
Bug fixes
  • #9891: Fix --auto-gen-config bug for Style/HashSyntax. ([@​jonas054][])
  • #9905: Fix false positive for single line concatenation in Layout/LineEndStringConcatenationIndentation. ([@​jonas054][])
  • #9907: Fix an incorrect auto-correct for Lint/UselessTimes when using block argument for 1.times. ([@​koic][])
  • #9869: Fix reference to file in configuration override warning. ([@​jonas054][])
  • #9902: Fix an incorrect auto-correct for Style/BlockDelimiters when there is a comment after the closing brace. ([@​koic][])
  • #8469: Add inspection of class << to Layout/SpaceAroundOperators. ([@​jonas054][])
  • #9909: This PR fixes an incorrect auto-correct for Style/SingleLineMethods when using return, break, or next for one line method body in Ruby 3.0. ([@​koic][])
  • #9914: Fix an error for Layout/HashAlignment when using aligned hash argument for proc.(). ([@​koic][])
Commits
  • a2fcc3d Cut 1.18.3
  • e327421 Update Changelog
  • ccdf562 Fix an incorrect auto-correct for Style/SingleLineMethods
  • cfdb0a1 [Fix #9902] Fix an incorrect auto-correct for Style/BlockDelimiters
  • e758a0d [Fix #9914] Fix an error for Layout/HashAlignment
  • e18a043 Merge pull request #9912 from jonas054/9869_fix_override_warning
  • 61dc5da Merge pull request #9901 from jonas054/9891_auto_gen_config_hash_syntax
  • d2fbf72 Fix a typo
  • 3e554da [Fix #9869] Print correct file in override warning
  • e5db7c0 Merge pull request #9911 from jonas054/9905_LineEndStringConcatenationIndenta...
  • Additional commits viewable in compare view
GitHub
