Build(deps): Bump rubocop from 1.18.3 to 1.18.4 (PR #13843)
Bumps rubocop from 1.18.3 to 1.18.4.
Release notes
Sourced from rubocop's releases.
RuboCop 1.18.4
New features
  • #9930: Support Ruby 2.7's pattern matching for Lint/DuplicateBranch cop. (@​koic)
Bug fixes
  • #9938: Fix an incorrect auto-correct for Layout/LineLength when a heredoc is used as the first element of an array. (@​koic)
  • #9940: Fix an incorrect auto-correct for Style/HashTransformValues when value is a hash literal for _.to_h{...}. (@​koic)
  • #9752: Improve error message for top level department used in configuration. (@​jonas054)
  • #9933: Fix GitHub Actions formatter when running in non-default directory. (@​ojab)
  • #9922: Make better auto-corrections in Style/DoubleCopDisableDirective. (@​jonas054)
  • #9848: Fix handling of comments in Layout/ClassStructure auto-correct. (@​jonas054)
  • #9926: Fix an incorrect auto-correct for Style/SingleLineMethods when method body is enclosed in parentheses. (@​koic)
  • #9928: Fix an infinite loop error and a false auto-correction behavior for Layout/EndAlignment when using operator methods and EnforcedStyleAlignWith: variable. (@​koic)
  • #9434: Fix false positive for setter calls in Layout/FirstArgumentIndentation. (@​jonas054)
Changelog
Sourced from rubocop's changelog.
1.18.4 (2021-07-23)
New features
  • #9930: Support Ruby 2.7's pattern matching for Lint/DuplicateBranch cop. ([@​koic][])
Bug fixes
  • #9938: Fix an incorrect auto-correct for Layout/LineLength when a heredoc is used as the first element of an array. ([@​koic][])
  • #9940: Fix an incorrect auto-correct for Style/HashTransformValues when value is a hash literal for _.to_h{...}. ([@​koic][])
  • #9752: Improve error message for top level department used in configuration. ([@​jonas054][])
  • #9933: Fix GitHub Actions formatter when running in non-default directory. ([@​ojab][])
  • #9922: Make better auto-corrections in Style/DoubleCopDisableDirective. ([@​jonas054][])
  • #9848: Fix handling of comments in Layout/ClassStructure auto-correct. ([@​jonas054][])
  • #9926: Fix an incorrect auto-correct for Style/SingleLineMethods when method body is enclosed in parentheses. ([@​koic][])
  • #9928: Fix an infinite loop error and a false auto-correction behavior for Layout/EndAlignment when using operator methods and EnforcedStyleAlignWith: variable. ([@​koic][])
  • #9434: Fix false positive for setter calls in Layout/FirstArgumentIndentation. ([@​jonas054][])
Commits
  • d6fb135 Cut 1.18.4
  • 6da5ca1 Update Changelog
  • 4874caa [Fix #9940] Fix an incorrect auto-correct for Style/HashTransformValues
  • 36029ff Support Ruby 2.7's pattern matching for Lint/DuplicateBranch
  • dfb9c26 [Fix #9752] Improve error message for top level department
  • 0886479 Fix an incorrect auto-correct for Layout/LineLength
  • 3907e07 Merge pull request #9932 from koic/fix_false_autocorrection_for_layout_end_al...
  • f2c5f0e Use offense instead of offence
  • 82d7122 Merge pull request #9937 from jonas054/9922_fix_DoubleCopDisableDirective
  • 49b3999 [Fix #9922] Replace extra disable directives with comma
  • Additional commits viewable in compare view
GitHub
