Build(deps): Bump rubocop from 1.18.4 to 1.19.0 (PR #14036)
Bumps rubocop from 1.18.4 to 1.19.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.19
New features
  • #4182: Add Lint/AmbiguousRange cop to check for ranges with ambiguous boundaries. (@​dvandersluis)
  • #10000: Parallel static analysis by default. (@​koic)
  • #9948: Support Ruby 2.7's pattern matching for Style/ConditionalAssignment cop. (@​koic)
  • #9999: Add new Style/RedundantSelfAssignmentBranch cop. (@​koic)
Bug fixes
  • #9927: Indent hash values in Layout/LineEndStringConcatenationIndentation. (@​jonas054)
  • #9959: Make Style/IdenticalConditionalBranches able to handle ternary ifs. (@​dvandersluis)
  • #9946: Avoid slow regexp matches in Style/CommentedKeyword. (@​jonas054)
  • #7422: Treat constant assignment like other assignment in Layout/SpaceAroundOperators. (@​dvandersluis)
  • #9953: Fix an infinite loop error and a false auto-correction behavior for Layout/EndAlignment when using a conditional statement in a method argument. (@​koic)
  • #9958: Prevent an infinite loop when a detected method has fewer arguments than expected. (@​dvandersluis)
  • #9977: Update Layout/EmptyLineAfterGuardClause to not register an offense if there is another expression following the guard clause on the same line. (@​dvandersluis)
  • #9980: Fix a false positive for Style/IdenticalConditionalBranches when assigning to a variable used in a condition. (@​koic)
  • #9975: Parentheses are always required for Style/MethodDefParentheses when a forwarding argument (...) is used. (@​dvandersluis)
  • #9984: Fix false negatives involving heredocs for Layout/SpaceBeforeComma, Layout/SpaceBeforeComment, Layout/SpaceBeforeSemicolon and Layout/SpaceInsideParens. (@​dvandersluis)
  • #9954: Fix infinite loop error for Layout/HashAlignment when EnforcedStyle: with_fixed_indentation is specified for Layout/ArgumentAlignment. (@​koic)
  • #10002: Fix an incorrect auto-correct for Lint/AmbigousRegexpLiteral when using nested method arguments without parentheses. (@​koic)
  • #9952 rubocop-rspec#1126: Fix inherit_mode for deeply nested configuration defined in extensions' default configuration. (@​pirj)
  • #9957: Add WholeWord configuration to Naming/InclusiveLanguage's FlaggedTerms config. (@​dvandersluis)
  • #9970: Don't register an offense when sort method has arguments for Style/RedundantSort cop. (@​mtsmfm)
  • #4097: Add require English for special globals. (@​biinari)
  • #9955: Fix Style/ExplicitBlockArgument adding a second set of parentheses. (@​dvandersluis)
  • #9973: Fix a false positive for Layout/RescueEnsureAlignment when aligned rescue keyword and leading dot. (@​koic)
  • #9945: Fix auto-correction of lines in heredocs with only spaces in Layout/TrailingWhitespace. (@​jonas054)
Changes
  • #9989: Mark Style/CommentedKeyword as unsafe auto-correction. (@​koic)
  • #9964: Make Layout/LeadingCommentSpace aware of #:nodoc. (@​koic)
  • #9985: Mark Style/IdenticalConditionalBranches as unsafe auto-correction. (@​koic)
  • #9962: Update Style/WordArray to register an offense in percent style if any values contain spaces. (@​dvandersluis)
  • #9979: Enable basic autocorrection for Style/Semicolon. (@​dvandersluis)
Changelog
Sourced from rubocop's changelog.
1.19.0 (2021-08-12)
New features
  • #4182: Add Lint/AmbiguousRange cop to check for ranges with ambiguous boundaries. ([@​dvandersluis][])
  • #10000: Parallel static analysis by default. ([@​koic][])
  • #9948: Support Ruby 2.7's pattern matching for Style/ConditionalAssignment cop. ([@​koic][])
  • #9999: Add new Style/RedundantSelfAssignmentBranch cop. ([@​koic][])
Bug fixes
  • #9927: Indent hash values in Layout/LineEndStringConcatenationIndentation. ([@​jonas054][])
  • #9959: Make Style/IdenticalConditionalBranches able to handle ternary ifs. ([@​dvandersluis][])
  • #9946: Avoid slow regexp matches in Style/CommentedKeyword. ([@​jonas054][])
  • #7422: Treat constant assignment like other assignment in Layout/SpaceAroundOperators. ([@​dvandersluis][])
  • #9953: Fix an infinite loop error and a false auto-correction behavior for Layout/EndAlignment when using a conditional statement in a method argument. ([@​koic][])
  • #9958: Prevent an infinite loop when a detected method has fewer arguments than expected. ([@​dvandersluis][])
  • #9977: Update Layout/EmptyLineAfterGuardClause to not register an offense if there is another expression following the guard clause on the same line. ([@​dvandersluis][])
  • #9980: Fix a false positive for Style/IdenticalConditionalBranches when assigning to a variable used in a condition. ([@​koic][])
  • #9975: Parentheses are always required for Style/MethodDefParentheses when a forwarding argument (...) is used. ([@​dvandersluis][])
  • #9984: Fix false negatives involving heredocs for Layout/SpaceBeforeComma, Layout/SpaceBeforeComment, Layout/SpaceBeforeSemicolon and Layout/SpaceInsideParens. ([@​dvandersluis][])
  • #9954: Fix infinite loop error for Layout/HashAlignment when EnforcedStyle: with_fixed_indentation is specified for Layout/ArgumentAlignment. ([@​koic][])
  • #10002: Fix an incorrect auto-correct for Lint/AmbigousRegexpLiteral when using nested method arguments without parentheses. ([@​koic][])
  • #9952 rubocop-rspec#1126: Fix inherit_mode for deeply nested configuration defined in extensions' default configuration. ([@​pirj][])
  • #9957: Add WholeWord configuration to Naming/InclusiveLanguage's FlaggedTerms config. ([@​dvandersluis][])
  • #9970: Don't register an offense when sort method has arguments for Style/RedundantSort cop. ([@​mtsmfm][])
  • #4097: Add require English for special globals. ([@​biinari][])
  • #9955: Fix Style/ExplicitBlockArgument adding a second set of parentheses. ([@​dvandersluis][])
  • #9973: Fix a false positive for Layout/RescueEnsureAlignment when aligned rescue keyword and leading dot. ([@​koic][])
  • #9945: Fix auto-correction of lines in heredocs with only spaces in Layout/TrailingWhitespace. ([@​jonas054][])
Changes
  • #9989: Mark Style/CommentedKeyword as unsafe auto-correction. ([@​koic][])
  • #9964: Make Layout/LeadingCommentSpace aware of #:nodoc. ([@​koic][])
  • #9985: Mark Style/IdenticalConditionalBranches as unsafe auto-correction. ([@​koic][])
  • #9962: Update Style/WordArray to register an offense in percent style if any values contain spaces. ([@​dvandersluis][])
  • #9979: Enable basic autocorrection for Style/Semicolon. ([@​dvandersluis][])
Commits
  • a6d8d92 Cut 1.19.0
  • 6d44d57 Update Changelog
  • cda3f43 [Fix #9980] Fix a false positive for Style/IdenticalConditionalBranches
  • 6907fa3 [Fix #9962] Update Style/WordArray to register an offense in percent styl...
  • 2fd1221 [Fix #9973] Fix a false positive for Layout/RescueEnsureAlignment
  • b3f6e50 [Fix #4182] Add Lint/AmbiguousRange cop to check for ranges with ambiguous ...
  • 07c8ef8 Add new Style/RedundantSelfAssignmentBranch cop
  • 0d5d736 Add doc and test for about pattern matching for Style/MissingElse
  • 499b3f6 Update StyleGuide URL for Style/WhenThen
  • 4363068 Update the doc for Style/BlockDelimiters
  • Additional commits viewable in compare view
GitHub
