Build(deps): Bump rubocop from 1.20.0 to 1.21.0 (PR #14331)
Bumps rubocop from 1.20.0 to 1.21.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.21
New features
Bug fixes
  • #10067: Fix an error for Lint/NumberConversion when using nested number conversion methods. (@​koic)
  • #10054: Fix a false positive for Layout/SpaceAroundOperators when match operators between << and +=. (@​koic)
  • #10061: Fix a false positive for Style/RedundantSort when using size method in the block. (@​koic)
  • #10063: Fix a false positive for Layout/SingleLineBlockChain when method call chained on a new line after a single line block with trailing dot. (@​koic)
  • #10064: Fix Style/ExplicitBlockArgument corrector assuming any existing block argument was named block. (@​byroot)
  • #10070: Fix a false positive for Style/MutableConstant when using non-interpolated heredoc in Ruby 3.0. (@​koic)
Changes
Changelog
Sourced from rubocop's changelog.
1.21.0 (2021-09-13)
New features
Bug fixes
  • #10067: Fix an error for Lint/NumberConversion when using nested number conversion methods. ([@​koic][])
  • #10054: Fix a false positive for Layout/SpaceAroundOperators when match operators between << and +=. ([@​koic][])
  • #10061: Fix a false positive for Style/RedundantSort when using size method in the block. ([@​koic][])
  • #10063: Fix a false positive for Layout/SingleLineBlockChain when method call chained on a new line after a single line block with trailing dot. ([@​koic][])
  • #10064: Fix Style/ExplicitBlockArgument corrector assuming any existing block argument was named block. ([@​byroot][])
  • #10070: Fix a false positive for Style/MutableConstant when using non-interpolated heredoc in Ruby 3.0. ([@​koic][])
Changes
Commits
  • 25112e6 Cut 1.21
  • 4593883 Update Changelog
  • f7c21e1 [Fix #9061] Add new Lint/IncompatibleIoSelectWithFiberScheduler cop
  • d199e94 Update Naming/InclusiveLanguage to be disabled by default.
  • eac703f [Fix #10070] Fix a false positive for Style/MutableConstant
  • 6d1ce3b Mark Style/AndOr as unsafe auto-correction
  • 1ad1f12 Fix an error for Lint/NumberConversion
  • b9de8e8 Merge pull request #10064 from casperisfine/explicit-block-corrector
  • e44b0a8 Style/ExplicitBlockArgument: do not assume the block parameter name
  • 8585c75 Merge pull request #10063 from koic/fix_a_false_positive_for_layout_single_li...
  • Additional commits viewable in compare view
GitHub
