Build(deps): Bump rubocop from 1.21.0 to 1.22.0 (PR #14476)
Bumps rubocop from 1.21.0 to 1.22.0.
Release notes
Sourced from rubocop's releases.
RuboCop 1.22
New features
Bug fixes
  • #10110: Update Layout/DotPosition to be able to handle heredocs. (@​dvandersluis)
  • #10134: Update Style/MutableConstant to not consider multiline uninterpolated strings as unfrozen in ruby 3.0. (@​dvandersluis)
  • #10124: Fix Layout/RedundantLineBreak adding extra space within method chains. (@​dvandersluis)
  • #10118: Fix crash with Style/RedundantSort when the block doesn't only contain a single send node. (@​dvandersluis)
  • #10135: Fix Style/WordArray to exclude files in --auto-gen-config when percent style is given but brackets are required. (@​dvandersluis)
  • #10090: Fix a false negative for Style/ArgumentsForwarding when using only kwrest arg. (@​koic)
  • #10099: UpdateStyle/RedundantFreeze to stop considering ENV values as immutable. (@​byroot)
  • #10078: Fix Layout/LineLength reported length when ignoring directive comments. (@​dvandersluis)
  • #9934: Fix configuration loading to not raise an error for an obsolete ruby version that is subsequently overridden. (@​dvandersluis)
  • #10136: Update Lint/AssignmentInCondition to not consider assignments within blocks in conditions. (@​dvandersluis)
  • #9588: Fix causing a variable to be shadowed from outside the rescue block in the logic of Naming/RescuedExceptionsVariableName. (@​lilisako)
  • #10096: Fix Lint/AmbiguousOperatorPrecedence with and/or operators. (@​dvandersluis)
  • #10106: Fix Style/RedundantSelf for pattern matching. (@​dvandersluis)
  • #10066: Fix how MinDigits is calculated for Style/NumericLiterals when generating a configuration file. (@​dvandersluis)
Changes
Changelog
Sourced from rubocop's changelog.
1.22.0 (2021-09-29)
New features
Bug fixes
  • #10110: Update Layout/DotPosition to be able to handle heredocs. ([@​dvandersluis][])
  • #10134: Update Style/MutableConstant to not consider multiline uninterpolated strings as unfrozen in ruby 3.0. ([@​dvandersluis][])
  • #10124: Fix Layout/RedundantLineBreak adding extra space within method chains. ([@​dvandersluis][])
  • #10118: Fix crash with Style/RedundantSort when the block doesn't only contain a single send node. ([@​dvandersluis][])
  • #10135: Fix Style/WordArray to exclude files in --auto-gen-config when percent style is given but brackets are required. ([@​dvandersluis][])
  • #10090: Fix a false negative for Style/ArgumentsForwarding when using only kwrest arg. ([@​koic][])
  • #10099: UpdateStyle/RedundantFreeze to stop considering ENV values as immutable. ([@​byroot][])
  • #10078: Fix Layout/LineLength reported length when ignoring directive comments. ([@​dvandersluis][])
  • #9934: Fix configuration loading to not raise an error for an obsolete ruby version that is subsequently overridden. ([@​dvandersluis][])
  • #10136: Update Lint/AssignmentInCondition to not consider assignments within blocks in conditions. ([@​dvandersluis][])
  • #9588: Fix causing a variable to be shadowed from outside the rescue block in the logic of Naming/RescuedExceptionsVariableName. ([@​lilisako][])
  • #10096: Fix Lint/AmbiguousOperatorPrecedence with and/or operators. ([@​dvandersluis][])
  • #10106: Fix Style/RedundantSelf for pattern matching. ([@​dvandersluis][])
  • #10066: Fix how MinDigits is calculated for Style/NumericLiterals when generating a configuration file. ([@​dvandersluis][])
Changes
Commits
  • 1bdcf65 Cut 1.22.0
  • 2c9664d Fix a changelog entry
  • a16bcb4 Update Changelog
  • 46d8867 [Fix #10135] Fix Style/WordArray to exclude files in --auto-gen-config wh...
  • e21a318 Merge pull request #10139 from dvandersluis/issue/10134
  • ed39d2b [Fix #10134] Update Style/MutableConstant to not consider multiline uninter...
  • 6dfc273 Merge pull request #10137 from dvandersluis/issue/10136
  • 45d8ed5 [Fix #10136] Update Lint/AssignmentInCondition to not consider assignments ...
  • 3a694f6 Update the message for Style/OptionalBooleanParameter.
  • a94b9fa Merge pull request #9961 from lilisako/fix-shadow-variable-in-rescued-excepti...
  • Additional commits viewable in compare view
GitHub
