Build(deps): Bump rubocop from 1.22.2 to 1.22.3 (PR #14753)
Bumps rubocop from 1.22.2 to 1.22.3.
Release notes
Sourced from rubocop's releases.
RuboCop 1.22.3
Bug fixes
  • #10166: Fix a false positive for Style/StringLiterals when using some meta characters (e.g. '\s', '\z') with EnforcedStyle: double_quotes. (@​koic)
  • #10216: Fix an incorrect autocorrect for Style/SelectByRegexp when using lvar =~ blockvar in a block. (@​koic)
  • #10207: Fix false positive in Layout/DotPosition when the selector is on the same line as the closing bracket of the receiver. (@​mvz)
Changes
  • #10209: Make Lint/DeprecatedConstants aware of Net::HTTPServerException. (@​koic)
Changelog
Sourced from rubocop's changelog.
1.22.3 (2021-10-27)
Bug fixes
  • #10166: Fix a false positive for Style/StringLiterals when using some meta characters (e.g. '\s', '\z') with EnforcedStyle: double_quotes. ([@​koic][])
  • #10216: Fix an incorrect autocorrect for Style/SelectByRegexp when using lvar =~ blockvar in a block. ([@​koic][])
  • #10207: Fix false positive in Layout/DotPosition when the selector is on the same line as the closing bracket of the receiver. ([@​mvz][])
Changes
  • #10209: Make Lint/DeprecatedConstants aware of Net::HTTPServerException. ([@​koic][])
Commits
  • 841bba4 Cut 1.22.3
  • dc872cb Update Changelog
  • 565a77d Fix a false positive for Style/StringLiterals
  • 6f92906 [Fix #10216] Fix an incorrect autocorrect for Style/SelectByRegexp
  • e93f705 Merge pull request #10213 from koic/fix_error_for_layout_block_alignment_usin...
  • 1c9abe9 Fix an error for Layout/BlockAlignment when using Ruby 3.1.0-dev
  • 00d940a Suppress warning: method redefined; discarding old warn_on_pending_cops
  • e1de418 Make Lint/DeprecatedConstants aware of Net::HTTPServerException
  • a6a94c4 Switch back the docs version
  • bf18dd3 Merge pull request #10207 from mvz/fix-dot-position
  • Additional commits viewable in compare view
GitHub
