Build(deps): Bump rubocop-rspec from 1.41.0 to 1.42.0 (PR #10207)
Bumps rubocop-rspec from 1.41.0 to 1.42.0.
Release notes
Sourced from rubocop-rspec's releases.
RuboCop RSpec v1.42.0
  • Update RuboCop dependency to 0.87.0 because of changes to internal APIs. (@bquorning, @Darhazer)
Changelog
Sourced from rubocop-rspec's changelog.
1.42.0 (2020-07-09)
  • Update RuboCop dependency to 0.87.0 because of changes to internal APIs. ([@bquorning][], [@Darhazer][])
Commits
GitHub
