Build(deps): Bump rubocop-rspec from 1.42.0 to 1.43.0 (PR #10453)
Bumps rubocop-rspec from 1.42.0 to 1.43.0.
Release notes
Sourced from rubocop-rspec's releases.
RuboCop RSpec v1.43.0
  • Add a new base cop class ::RuboCop::Cop::RSpec::Base. The old base class ::RuboCop::Cop::RSpec::Cop is deprecated, and will be removed in the next major release. (@bquorning)
  • Add support for subject detection after includes and example groups in RSpec/LeadingSubject. (@pirj)
  • Ignore trailing punctuation in context description prefix. ([@elliterate][])
  • Relax RSpec/VariableDefinition cop so interpolated and multiline strings are accepted even when configured to enforce the symbol style. (@bquorning)
  • Fix RSpec/EmptyExampleGroup to flag example groups with examples in invalid scopes. (@mlarraz)
  • Fix RSpec/EmptyExampleGroup to ignore examples groups with examples defined inside iterators. (@pirj)
  • Improve RSpec/NestedGroups, RSpec/FilePath, RSpec/DescribeMethod, RSpec/MultipleDescribes, RSpec/DescribeClass's top-level example group detection. (@pirj)
  • Add detection of let! with a block-pass or a string literal to RSpec/LetSetup. (@pirj)
  • Add IgnoredPatterns configuration option to RSpec/VariableName. ([@jtannas][])
  • Add RSpec/MultipleMemoizedHelpers cop. ([@mockdeep][])
Changelog
Sourced from rubocop-rspec's changelog.
1.43.0 (2020-08-17)
  • Add a new base cop class ::RuboCop::Cop::RSpec::Base. The old base class ::RuboCop::Cop::RSpec::Cop is deprecated, and will be removed in the next major release. ([@bquorning][])
  • Add support for subject detection after includes and example groups in RSpec/LeadingSubject. ([@pirj][])
  • Relax RSpec/VariableDefinition cop so interpolated and multiline strings are accepted even when configured to enforce the symbol style. ([@bquorning][])
  • Fix RSpec/EmptyExampleGroup to flag example groups with examples in invalid scopes. ([@mlarraz][])
  • Fix RSpec/EmptyExampleGroup to ignore examples groups with examples defined inside iterators. ([@pirj][])
  • Improve RSpec/NestedGroups, RSpec/FilePath, RSpec/DescribeMethod, RSpec/MultipleDescribes, RSpec/DescribeClass's top-level example group detection. ([@pirj][])
  • Add detection of let! with a block-pass or a string literal to RSpec/LetSetup. ([@pirj][])
Commits
  • 3d4f211 Merge pull request #998 from rubocop-hq/release
  • 589cd18 Bump version to v1.43.0
  • 5ac67ea Merge pull request #993 from biinari/fix/expect_offense_kwargs
  • a2ef166 Merge pull request #863 from mockdeep/rf-no_let
  • 986537f Improve the performance of MultipleMemoizedHelpers
  • 49e729d Allow %{name} replacements in specs
  • 166129e Pass kwargs to expect_offense
  • edb87e8 Enable MultipleMemoizedHelpers by default
  • 8d7b3c9 Add block-pass support to MultipleMemoizedHelpers
  • c3ab68f Allow for --auto-gen-config
  • Additional commits viewable in compare view
GitHub
Superseded by #10454.
