Build(deps): Bump rubocop-rspec from 1.43.1 to 1.43.2 (PR #10522)
Bumps rubocop-rspec from 1.43.1 to 1.43.2.
Release notes
Sourced from rubocop-rspec's releases.
RuboCop RSpec v1.43.2
  • Fix RSpec/FilePath when checking a file with a shared example. (@pirj)
  • Fix subject nesting detection in RSpec/LeadingSubject. (@pirj)
Changelog
Sourced from rubocop-rspec's changelog.
Change log
Master (Unreleased)
  • Move our documentation from rubocop-rspec.readthedocs.io to docs.rubocop.org/rubocop-rspec. ([@bquorning][])
  • Add RSpec/RepeatedIncludeExample cop. ([@biinari][])
  • Fix RSpec/FilePath when checking a file with a shared example. ([@pirj][])
  • Fix subject nesting detection in RSpec/LeadingSubject. ([@pirj][])
  • Fix false positives in RSpec/EmptyExampleGroup. ([@pirj][])
Commits
  • fd7009b Bump version to 1.43.2
  • 5723158 Merge pull request #1011 from rubocop-hq/fix-leading-subject
  • a57c6f1 Merge pull request #1009 from rubocop-hq/fix-file_path-cop-to-ignore-shared-g...
  • See full diff in compare view
GitHub
