Build(deps): Bump rubocop-rspec from 2.5.0 to 2.6.0 (PR #14851)
Bumps rubocop-rspec from 2.5.0 to 2.6.0.
Release notes
Sourced from rubocop-rspec's releases.
RuboCop RSpec v2.6.0
  • Fix merging RSpec DSL configuration from third-party gems. (@​pirj)
  • Fix RSpec/ExcessiveDocstringSpacing false positive for multi-line indented strings. (@​G-Rath)
  • Fix Include configuration for sub-departments. (@​pirj)
  • Ignore heredocs in RSpec/ExcessiveDocstringSpacing. (@​G-Rath)
  • Stop RSpec/ExampleWording from trying to correct heredocs. (@​G-Rath)
  • Add autocorrect support for RSpec/VariableDefinition. (@​r7kamura)
Changelog
Sourced from rubocop-rspec's changelog.
2.6.0 (2021-11-08)
  • Fix merging RSpec DSL configuration from third-party gems. ([@​pirj][])
  • Fix RSpec/ExcessiveDocstringSpacing false positive for multi-line indented strings. ([@​G-Rath][])
  • Fix Include configuration for sub-departments. ([@​pirj][])
  • Ignore heredocs in RSpec/ExcessiveDocstringSpacing. ([@​G-Rath][])
  • Stop RSpec/ExampleWording from trying to correct heredocs. ([@​G-Rath][])
  • Add autocorrect support for RSpec/VariableDefinition. ([@​r7kamura][])
Commits
  • 6683d5f Merge pull request #1208 from rubocop/release
  • 82ac3ea Bump version to 2.6.0
  • 96aa010 Merge pull request #1084 from rubocop/github-actions
  • 52baf6e Remove simplecov gem and related rake task
  • 6e40b38 Stop sending coverage data do Code Climate
  • ee19e9f Move from CircleCI to GitHub Actions
  • 8821470 Merge pull request #1204 from r7kamura/feature/variable-definition-auto-correct
  • 02a03b7 Add autocorrect support for RSpec/VariableDefinition
  • 6d1cd98 Merge pull request #1203 from koic/fix_error_when_running_rake_new_cop
  • fe07b32 Fix an error when running rake new_cop
  • Additional commits viewable in compare view
GitHub
