Build(deps): Bump ruby2_keywords from 0.0.4 to 0.0.5 (PR #13771)
Bumps ruby2_keywords from 0.0.4 to 0.0.5.
Commits
  • 92ad9c5 Add TruffleRuby in CI
  • 07d7fa1 bundle-install only on ruby 2.1
  • 5f993b8 Split Rakefile into rakelib
  • 8e4d9a8 Ignore lock file and generated logs
  • 03b864c Do not use gemspec for gem dependecy
  • 636c350 Reduced tests
  • 97b4de7 Add docker-compose.yml for easy testing of older rubies
  • 6974495 Explicitly declare support for Ruby >= 2.0.0
  • 64aad91 Separated install from test
  • 74cb318 Add older Rubies to CI as well
  • Additional commits viewable in compare view
GitHub
