Build(deps): Bump rubyzip from 1.2.3 to 1.3.0 (PR #8115)
Bumps rubyzip from 1.2.3 to 1.3.0.
Release notes
Sourced from rubyzip’s releases.
v1.3.0
Security
  • Add validate_entry_sizes option so that callers can trust an entry’s reported size when using extract #403
    • This option defaults to false for backward compatibility in this release, but you are strongly encouraged to set it to true. It will default to true in rubyzip 2.0.
New Feature
  • Add add_stored method to simplify adding entries without compression #366
Tooling / Documentation
  • Add more gem metadata links #402
v1.2.4
  • Do not rewrite zip files opened with open_buffer that have not changed #360
  • Update example_recursive.rb in README #397
  • Hold CI at trusty for now, automatically pick the latest ruby patch version, use rbx-4 and hold jruby at 9.1 #399
Changelog
Sourced from rubyzip’s changelog.
1.3.0 (2019-09-25)
Security
New Feature
1.2.4 (2019-09-06)
Commits
  • e79d9ea Merge pull request #407 from rubyzip/v1-3-0
  • 7c65e1e Bump version to 1.3.0
  • d65fe7b Merge pull request #403 from rubyzip/check-size
  • 97cb6ae Warn when an entry size is invalid
  • 7849f73 Default validate_entry_sizes to false for 1.3 release
  • 4167f0c Validate entry sizes when extracting
  • 94b7fa2 [ci skip] Update changelog
  • 93505ca Check expected entry size in add_stored test
  • 6619bf3 Merge pull request #366 from hainesr/add-stored
  • ecb2776 Zip::File.add_stored() to add uncompressed files.
  • Additional commits viewable in compare view
  • @dependabot ignore this [patch|minor|major] version will close this PR and stop Dependabot creating any more for this minor/major version (unless you reopen the PR or upgrade to it yourself)
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
Thanks for contributing this pull request! Could you please sign our CLA so we can review it? http://www.discourse.org/cla
Looks like rubyzip is up-to-date now, so this is no longer needed.
