Build(deps): Bump rubyzip from 2.3.0 to 2.3.1 (PR #13626)
Bumps rubyzip from 2.3.0 to 2.3.1.
Release notes
Sourced from rubyzip's releases.
v2.3.1
This is a "dummy" release to warn about breaking changes coming in version 3.0.
Changelog
Sourced from rubyzip's changelog.
2.3.1 (2021-07-03)
  • A "dummy" release to warn about breaking changes coming in version 3.0.
Commits
  • 16de339 Print banner text re v3.0.0 when zip is required.
  • 84d7a66 Bump version number and Changelog.
  • See full diff in compare view
GitHub
