Build(deps): Bump sanitize from 5.2.2 to 5.2.3 (PR #11697)
Bumps sanitize from 5.2.2 to 5.2.3.
Release notes
Sourced from sanitize's releases.
v5.2.3
Bug Fixes
  • Ensure protocol sanitization is applied to data attributes. [@ccutrer - #207]207
Changelog
Sourced from sanitize's changelog.
5.2.3 (2021-01-11)
Bug Fixes
Commits
GitHub
