Build(deps): Bump sidekiq from 6.0.4 to 6.0.5 (PR #8964)
Bumps sidekiq from 6.0.4 to 6.0.5.
Changelog
Sourced from sidekiq's changelog.
6.0.5
  • Fix broken Web UI response when using NewRelic and Rack 2.1.2+. #4440
  • Update APIs to use UNLINK, not DEL. #4449
  • Fix Ruby 2.7 warnings #4412
Commits
GitHub
Thanks for contributing this pull request! Could you please sign our CLA so we can review it? http://www.discourse.org/cla
