Build(deps): Bump sidekiq from 6.0.7 to 6.1.0 (PR #10151)
Bumps sidekiq from 6.0.7 to 6.1.0.
Changelog
Sourced from sidekiq's changelog.
6.1.0
  • Web UI - Dark Mode fixes [#4543, natematykiewicz]
  • Ensure Rack::ContentLength is loaded as middleware for correct Web UI responses #4541
  • Avoid exception dumping SSL store in Redis connection logging #4532
  • Better error messages in Sidekiq::Client #4549
  • Remove rack-protection, reimplement CSRF protection #4588
  • Require redis-rb 4.2 #4591
  • Update to jquery 1.12.4 #4593
  • Refactor internal fetch logic and API #4602
Commits
GitHub
There seem to be some sidekiq failures here when restoring backups.
@ZogStriP looks like you wrote this code… 7 years ago :stuck_out_tongue: It might need to be updated for sidekiq changes?
@gschlager knows that code better than anybody else.
Blocked by https://github.com/resque/redis-namespace/issues/172
We could potentially monkey patch us out of this if we want to upgrade right now. https://github.com/tootsuite/mastodon/pull/14191 seems to include a working patch.
I don’t think upgrading is urgent right now. Let’s skip this one.
OK, I won’t notify you about version 6.1.x again, unless you re-open this PR or update to a 6.1.x release yourself.
Reopening since we updated the redis-namespace gem today.
Superseded by #10518.
