Build(deps): Bump sidekiq from 6.0.7 to 6.1.1 (PR #10518)
Bumps sidekiq from 6.0.7 to 6.1.1.
Changelog
Sourced from sidekiq's changelog.
6.1.1
  • Jobs are now sorted by age in the Busy Workers table. #4641
  • Fix "check all" JS logic in Web UI #4619
6.1.0
  • Web UI - Dark Mode fixes [#4543, natematykiewicz]
  • Ensure Rack::ContentLength is loaded as middleware for correct Web UI responses #4541
  • Avoid exception dumping SSL store in Redis connection logging #4532
  • Better error messages in Sidekiq::Client #4549
  • Remove rack-protection, reimplement CSRF protection #4588
  • Require redis-rb 4.2 #4591
  • Update to jquery 1.12.4 #4593
  • Refactor internal fetch logic and API #4602
Commits
GitHub
Seems pretty safe so trying this out.
