Build(deps): Bump sidekiq from 6.1.1 to 6.1.2 (PR #10624)
Bumps sidekiq from 6.1.1 to 6.1.2.
Changelog
Sourced from sidekiq's changelog.
6.1.2
  • Improve readability in dark mode Web UI #4674
  • Fix Web UI crash with corrupt session #4672
  • Allow middleware to yield arguments [#4673, @eugeneius]
  • Migrate CI from CircleCI to GitHub Actions #4677
Commits
GitHub
