Build(deps): Bump sidekiq from 6.2.0 to 6.2.1 (PR #12644)
Bumps sidekiq from 6.2.0 to 6.2.1.
Changelog
Sourced from sidekiq's changelog.
6.2.1
  • Update RTT warning logic to handle transient RTT spikes #4851
  • Fix very low priority CVE on unescaped queue name #4852
  • Add note about sessions and Rails apps in API mode
Commits
GitHub
