Build(deps): Bump simplecov-html from 0.12.2 to 0.12.3 (PR #10731)
Bumps simplecov-html from 0.12.2 to 0.12.3.
Release notes
Sourced from simplecov-html's releases.
v0.12.3
Bugfixes
  • Relax ruby version requirement to work with Ruby 3.0 (next version, current ruby-head). Thanks @byroot.
Changelog
Sourced from simplecov-html's changelog.
0.12.3 (2020-09-23)
Bugfixes
Commits
  • 3a30b47 make choice of simplecov explicit
  • ed0a3e5 0.12.3 version bump which I of course forgot...
  • ef9fb3c simplecov-core doesn't support Ruby 2.4 anymore
  • c32c38d Update references to correct repo
  • ada2bf9 User relevant changelog for 0.12.3
  • 7b20041 Update Ruby & simplecov reference
  • 6567856 Update ruby_version requirement to allow ruby 3.0
  • 7d1db36 Bump rack from 2.1.2 to 2.2.3
  • bdcaca2 Remove sass dependency
  • See full diff in compare view
GitHub
