Build(deps): Bump simplecov_json_formatter from 0.1.2 to 0.1.3 (PR #12934)
Bumps simplecov_json_formatter from 0.1.2 to 0.1.3.
Changelog
Sourced from simplecov_json_formatter's changelog.
0.1.3 (2021-05-02)
Bugfixes
Commits
GitHub
seems safe and test failure looks unrelated
