Build(deps): Bump sprockets-rails from 3.2.1 to 3.2.2 (PR #10660)
Bumps sprockets-rails from 3.2.1 to 3.2.2.
Commits
  • 1bf94e2 Prepare 3.2.2 release
  • 45a1b7a Merge pull request #465 from rails/fix-tests-and-add-ruby-2-7
  • 66fd4ab Fix extending ActionView::Base instances
  • 3ad8f0d Silence warnings about static path fallback
  • fc1badb Fix Action View deprecation warning
  • 06b1fdf Require Rails::VERSION so test can run in isolation
  • b86310c Fix Sprockets deprecation warning
  • c388c28 Only use kwargs splat operator on Ruby 2.7+
  • 789c682 Exclude Rails 5.2.x/Ruby 2.2 from build matrix
  • ff96fc7 Update ruby version testing matrix
  • Additional commits viewable in compare view
GitHub
