Build(deps): Bump sprockets-rails from 3.2.2 to 3.3.0 (PR #14891)
Bumps sprockets-rails from 3.2.2 to 3.3.0.
Release notes
Sourced from sprockets-rails's releases.
v3.3.0
What's Changed
Full Changelog: https://github.com/rails/sprockets-rails/compare/v3.2.2...v3.3.0
Commits
  • 58dbb85 Bump for 3.3.0
  • ccf8411 Process css files so that they get digested paths for asset files (#476)
  • 118ce60 Merge pull request #475 from hahmed/ha/move-to-gitub-actions
  • 5fb466d Fixes build for Gemfile, rails 7 by adding a new method that checks the rails...
  • 1f6eba8 Move to github actions
  • 5c0ecb0 Merge pull request #472 from ghiculescu/use-the-good-error
  • 22b1747 Raise the error that includes an error message
  • 1a0cf7a Merge pull request #469 from skatkov/travis-remove-unsupported-versions
  • 35ecc3f Update gemspec with minimum ruby/rails versions
  • 2393d90 Travis-ci: remove unsupported rubies and rails versions
  • See full diff in compare view
GitHub
