Build(deps): Bump ssri from 6.0.1 to 6.0.2 in /support/text-unicode-webpack (PR #12)
Bumps ssri from 6.0.1 to 6.0.2.
Changelog
Sourced from ssri's changelog.
6.0.2 (2021-04-07)
Bug Fixes
  • backport regex change from 8.0.1 (b30dfdb), closes #19
Commits
Maintainer changes
This version was pushed to npm by nlf, a new releaser for ssri since your current version.
You can disable automated security fix PRs for this repo from the Security Alerts page.
GitHub
