Build(deps): Bump tzinfo from 1.2.6 to 1.2.7 (PR #9340)
Bumps tzinfo from 1.2.6 to 1.2.7.
Changelog
Sourced from tzinfo's changelog.
Version 1.2.7 - 2-Apr-2020
  • Fixed 'wrong number of arguments' errors when running on JRuby 9.0. #114.
  • Fixed warnings when running on Ruby 2.8. #112.
Commits
  • 97f73b2 Improve grammar.
  • e944161 Preparing v1.2.7.
  • f7487ef Update to Ruby 2.7.1.
  • 4610d36 Revert to Ruby 2.4.9 and 2.7.0.
  • 93cb2b4 Update to Ruby 2.4.10, 2.5.8, 2.6.6, 2.7.1 and JRuby 9.2.11.1.
  • 171f059 Use shields.io for badges.
  • 0fcafc2 Update copyright years.
  • fcaf868 Add a build status badge for AppVeyor.
  • 0876b26 Replace broken links.
  • 1f81e20 Use https for links where available.
  • Additional commits viewable in compare view
GitHub
